- To:
- Subject: Re: [cgal-discuss] Segment Inside a Polygon
- Date: Thu, 2 Feb 2012 23:27:55 +0100
Hi Prateek,
The function CGAL::bounded_side_2 computes if a point lies inside a polygon. Please check the reference manual for its usage.
#include <CGAL/Polygon_2_algorithms.h>
An example of how to use this function is also given in the Polygon chapter of the CGAL Manual.
Hope this helps.
Best regards,
Sandeep.
On Thu, Feb 2, 2012 at 8:06 PM, pgiitu <> wrote:
Hello
I am new to CGAl and I need to check whether there is a way to check if a
line segment lies completely inside a polygon or not.
The file intersection.h in CGAL offers intersection of line vs live,
triangle vs line and many more options but not a polygon.
Can anyone help me?
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Segment-Inside-a-Polygon-tp4352456p4352456.html
- [cgal-discuss] Segment Inside a Polygon, pgiitu, 02/02/2012
- Re: [cgal-discuss] Segment Inside a Polygon, Sandeep Dey, 02/02/2012
- [cgal-discuss] Re: Segment Inside a Polygon, pgiitu, 02/03/2012
- Re: [cgal-discuss] Re: Segment Inside a Polygon, Sandeep Dey, 02/03/2012
- Re: [cgal-discuss] Re: Segment Inside a Polygon, Sebastien Loriot (GeometryFactory), 02/03/2012
