cgal-discuss - [cgal-discuss] Re: Segment Inside a Polygon
  • To:
  • Subject: [cgal-discuss] Re: Segment Inside a Polygon
  • Date: Fri, 3 Feb 2012 02:03:44 -0800 (PST)
Hello Sandeep,
Thanks for the help but I would like to emphasize that point inside a
polygon and line segment inside a polygon are two very different problems.
Even after counting the no. of intersections it is not possible to tell
whether the whole line segment is inside the polygon or not.
For Ex consider the following image in the file
http://cgal-discuss.949826.n4.nabble.com/file/n4354159/imagepdf.pdf
imagepdf.pdf
For the two red line segments the no of intersections are the same in every
case. so The no of intersections thing will not work.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Segment-Inside-a-Polygon-tp4352456p4354159.html
