cgal-discuss - Re: [cgal-discuss] CGAL web UI
  • To:
  • Subject: Re: [cgal-discuss] CGAL web UI
  • Date: Fri, 03 Feb 2012 08:23:50 +0100
On 02/03/2012 07:46 AM, Mohammed Rashad wrote:
Hi All,
Is there any web UI for CGAL?
I am working on GIS area and building some UI for mapping stuff. Today I
met a guy in campus and he told me about CGAL. I have heard it before
but dont know much about it. So i thought to give it a try.
I would like to know is there any web interface for CGAL??
Right now there is nothing like that, just ipe, scilab, java and python bindings (last two using SWIG).
Will it be worth if there is one?. the answer to the above said question
will direct to me to a new project which will be CGAL webUI. I am using
C++ for web development using a C++ web Toolkit. and if CGAL is also in
C++. I can link CGAL libraries with the web application and we will have
a CGAL webUI as same as a Desktop UI.
The main thing I need to know is how will be the performace because I
recently created a webGRASS for GRASS GIS desktop which runs on web
which pays off me very very poor performance.
*so will these algorithms need more time to run if on web. Will these
handle very large data that a web application cannot handle?*
Except for online demos of CGAL algorithms which would be very nice,
I don't really get the point of doing this (but I'm probably missing
something here). CGAL is usually meant to be used as components for a
higher level application.
For performance issues, it really depends on the algorithm you are
looking at. If you want to try something I would suggest to start with Delaunay_triangulation_2.
By curiosity can you give a link to a something you did available
online?
Sebastien.
Regards,
Rashad
  • [cgal-discuss] CGAL web UI, Mohammed Rashad, 02/03/2012
    • Re: [cgal-discuss] CGAL web UI, Sebastien Loriot (GeometryFactory), 02/03/2012
