- To:
- Subject: Re: [cgal-discuss] re-implementing OGL_helper.h and copyright
- Date: Fri, 03 Feb 2012 08:30:54 +0100
On 01/31/2012 08:12 AM, Don Bright wrote:
Hello CGAL,From what I get, if this is a patch to a file under QPL license, the copyright remains to the original author.
I have re-implemented the functionality of OGL_helper.h by rewriting
the whole thing. Would the Max-Planck-Institute consider the
re-implementation to still be covered by their copyright, or is it
under my copyright?
Note that even if you were sharing the copyright you are not allowed to
change the license of a file without the agreement of the other
copyright holders.
We probably be able to solve this issue next week.
My code uses the 'visitor' pattern of Nef polyhedron3 as described in
the CGAL manual, and feeds the results to GLUtess. The code is not the
same as OGL_helper.h, but it does bear a resemblance; there are only
so many ways to iterate through a facet cycle after all (I use next()
on a shalfedge_const_handle).
The reason for re-implementation instead of subclassing is to get more
control over the colors and the GLUtess code, and to make the OpenSCAD
project fully GPL.
Sebastien.
Thank you
-Don B
- Re: [cgal-discuss] re-implementing OGL_helper.h and copyright, Sebastien Loriot (GeometryFactory), 02/03/2012
- Re: [cgal-discuss] re-implementing OGL_helper.h and copyright, Don Bright, 02/04/2012
