- To:
- Subject: Re: [cgal-discuss] Slhouette: From 3d to 2d
- Date: Sat, 4 Feb 2012 22:01:45 +0200
Recently (very recently), we have published a book enitled "CGAL Arrangements and Their Applications" [1]. The book contains several examples including one that computes the silhouette of a polyhedron called polygon_orientation.cpp[3]. It may depend on other header files available at at [2].
[1] http://www.springer.com/computer/image+processing/book/978-3-642-17282-3
[2] http://acg.cs.tau.ac.il/cgal-arrangement-book
[3] http://acg.cs.tau.ac.il/cgal-arrangement-book/examples/chapter-5/ex_polygon_orientation.cpp
On Thu, Feb 2, 2012 at 11:28 PM, noel <> wrote:
I have a 3D Nef polyhedron. I want a 2D polygon representing the silhouette
of that polyhedron (bird's eye view). I've been looking at Envelopes but am
unsure if that is the way to proceed. Wouldn't it be easier just to glide
it through the xy plane, intersect it there and then use that intersection
to build my polygon?
If envelopes are the correct way to do this, I find the three examples are a
little too different to what I need to be of any real use. Does anyone have
a better example lying around the place?
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Slhouette-From-3d-to-2d-tp4352895p4352895.html
- [cgal-discuss] Slhouette: From 3d to 2d, noel, 02/02/2012
- Re: [cgal-discuss] Slhouette: From 3d to 2d, Sebastien Loriot (GeometryFactory), 02/03/2012
- [cgal-discuss] Re: Slhouette: From 3d to 2d, noel, 02/03/2012
- Re: [cgal-discuss] Slhouette: From 3d to 2d, Efi Fogel, 02/04/2012
