cgal-discuss - Re: [cgal-discuss] Slhouette: From 3d to 2d
  • To:
  • Subject: Re: [cgal-discuss] Slhouette: From 3d to 2d
  • Date: Fri, 03 Feb 2012 08:58:36 +0100
If your nef polyhedron is simple you can export it to a Polyhedron_3
(facets will be automatically triangulated) and use that example:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Envelope_3/Chapter_main.html#Subsection_35.3.1
To get the triangles you can use a boost::transform iterator over
the range P.facets_begin (),P.facets_end().
see also:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Nef_3_ref/Class_Nef_polyhedron_3.html#Function_void_convert_to_polyhedron6Polyhedron__P9_const;
On 02/02/2012 10:28 PM, noel wrote:
I have a 3D Nef polyhedron. I want a 2D polygon representing the silhouette
of that polyhedron (bird's eye view). I've been looking at Envelopes but am
unsure if that is the way to proceed. Wouldn't it be easier just to glide
it through the xy plane, intersect it there and then use that intersection
to build my polygon?
If envelopes are the correct way to do this, I find the three examples are a
little too different to what I need to be of any real use. Does anyone have
a better example lying around the place?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Slhouette-From-3d-to-2d-tp4352895p4352895.html
