- To:
- Subject: Re: [cgal-discuss] partitionning Polygon_2 with holes
- Date: Mon, 06 Feb 2012 17:30:48 +0100
On 02/06/2012 05:23 PM, Thomas Recouvreux wrote:
A triangulation is by definition triangulated, so you can't do that
2012/2/6 Sebastien Loriot (GeometryFactory)
<mailto:>>
On 02/06/2012 05:11 PM, Thomas Recouvreux wrote:
Hi,
Thanks the Delaunay triangulation works well.
Do you have a piece of code to remove edges ?
Do you mean removing constrained edges?
No I mean remove some edges to fusion triangle into convex polygons.
with a Triangulation as underlying data structure.
To do that you need to export your triangulated polygon into another
data structure such as the Halfedge data structure for example
(http://www.cgal.org/Manual/latest/doc_html/cgal_manual/HalfedgeDS/Chapter_main.html)
And is there an index for each faces or shall I put it in FaceInfo
structure ?
You need to use Face_with_info.
Note that a Face_handle can be use as a key in a map for example.
How can I use Face_handle as a key ??
Face_handle object are comparable so you can use for example:
typedef std::set<Face_handle> Face_handle_set;
Sebastien.
Sebastien.
Thomas
2012/1/18 Mariette Yvinec
<mailto:>
<mailto:
<mailto:>>>
Starting from the constrained triangulation of your polygons
you can appraoch a minimal convex subdivision
(I think at most twice the number of parts of the optimal)
by pulling out as much as you can
of non constrained triangulation edges
without forming angles greater than 90 degrees.
Le 18/01/12 09:27, Sebastien Loriot (GeometryFactory) a écrit :
The input polygon should be simple and without holes.
In you case you might want to try to use a constrained
(Delaunay)
triangulation (edges of your polygon are constraints).
The decomposition would be minimal at all but it will be
convex.
See:
http://www.cgal.org/Manual/__latest/doc_html/cgal_manual/__Triangulation_2/Chapter_main.__html#Section_36.7
<http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Section_36.7>
Sebastien.
Hi,
I've have found some examples about partitionning a
Polygon_2,
but I didn't see functions for partitionning a
Poly_2 with holes.
Is there any function to do so or shall I decompose
first my
polygon with holes in polygons without holes and
apply the
partitionning function ?
An other question, I tried to use partition function
on a polygon
with tangente edges (see below), and the function
return the
whole polygon without partionning it, did I miss
something ?
+-----------------------------__----------+
polygon.push_back(Point_2(0, 0));
polygon.push_back(Point_2(10, 0));
polygon.push_back(Point_2(6, 2));
polygon.push_back(Point_2(2, 2));
polygon.push_back(Point_2(2, 6));
polygon.push_back(Point_2(6, 6));
polygon.push_back(Point_2(10, 10));
polygon.push_back(Point_2(0,__10));
Best
Thomas
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
https://lists-sop.inria.fr/__wws/info/cgal-discuss
<https://lists-sop.inria.fr/wws/info/cgal-discuss>
- Re: [cgal-discuss] partitionning Polygon_2 with holes, Thomas Recouvreux, 02/06/2012
- Re: [cgal-discuss] partitionning Polygon_2 with holes, Sebastien Loriot (GeometryFactory), 02/06/2012
- Re: [cgal-discuss] partitionning Polygon_2 with holes, Thomas Recouvreux, 02/07/2012
