- To:
- Subject: Re: [cgal-discuss] partitionning Polygon_2 with holes
- Date: Tue, 7 Feb 2012 19:54:33 +0100
Hi,
it->neighbor(i)->info().index doesn't work for me, I don't understand why (the compilation fails).
Finally I used the adress of FaceHandle as key (index = &(*it)) and that works well.
I succeeded in making my navgraph and use it after the export of the triangulation to python. Thanks for your help !
I will try later to export the triangulation to HDS in order to remove useless edges, I'll let you know.
Thomas
2012/2/6 Sebastien Loriot (GeometryFactory) <>
On 02/06/2012 06:31 PM, Thomas Recouvreux wrote:try with
Hi again,
In fact I would like to export my partition, for my export I need for
example a list of indexed faces with the index of their neighbors.
I tried to put an "index" variable in FaceInfo, that works well when I
iterate other faces (it->infos().index), but
it->neighbor(i).info().index fails at compilation ( [...] Face_handle’
has no member named ‘info’).
it->neighbor(i)->info().indexHDS is low level layer so there is no high level function.
Is their an easy way to export triangulation to halfedge structure ?
It's not complicated and the documentation is well written, but you
need to do it by hand or using the decorator class.
see
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/HalfedgeDS/Chapter_main.html
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/HalfedgeDS_ref/Class_HalfedgeDS_decorator.html#Cross_link_anchor_1120
<mailto: <mailto:>>>
<mailto:>>
< <mailto:>(http://www.cgal.org/Manual/__latest/doc_html/cgal_manual/__HalfedgeDS/Chapter_main.html
On 02/06/2012 05:11 PM, Thomas Recouvreux wrote:
Hi,
Thanks the Delaunay triangulation works well.
Do you have a piece of code to remove edges ?
Do you mean removing constrained edges?
No I mean remove some edges to fusion triangle into convex polygons.
A triangulation is by definition triangulated, so you can't do that
with a Triangulation as underlying data structure.
To do that you need to export your triangulated polygon into another
data structure such as the Halfedge data structure for example
<http://www.cgal.org/Manual/latest/doc_html/cgal_manual/HalfedgeDS/Chapter_main.html>)<mailto:. <mailto:.>____fr
And is there an index for each faces or shall I put it
in FaceInfo
structure ?
You need to use Face_with_info.
Note that a Face_handle can be use as a key in a map for
example.
How can I use Face_handle as a key ??
Face_handle object are comparable so you can use for example:
typedef std::set<Face_handle> Face_handle_set;
Sebastien.
Sebastien.
Thomas
2012/1/18 Mariette Yvinec <
<mailto:>
<mailto:__fr
<mailto:>>http://www.cgal.org/Manual/____latest/doc_html/cgal_manual/____Triangulation_2/Chapter_main.____html#Section_36.7
<mailto:__fr
<mailto:>>>>
Starting from the constrained triangulation of your
polygons
you can appraoch a minimal convex subdivision
(I think at most twice the number of parts of the
optimal)
by pulling out as much as you can
of non constrained triangulation edges
without forming angles greater than 90 degrees.
Le 18/01/12 09:27, Sebastien Loriot
(GeometryFactory) a écrit :
The input polygon should be simple and without
holes.
In you case you might want to try to use a
constrained
(Delaunay)
triangulation (edges of your polygon are
constraints).
The decomposition would be minimal at all but it
will be
convex.
See:
<http://www.cgal.org/Manual/__latest/doc_html/cgal_manual/__Triangulation_2/Chapter_main.__html#Section_36.7>+-----------------------------____----------+
<http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Section_36.7>>
Sebastien.
Hi,
I've have found some examples about
partitionning a
Polygon_2,
but I didn't see functions for partitionning a
Poly_2 with holes.
Is there any function to do so or shall I
decompose
first my
polygon with holes in polygons without holes and
apply the
partitionning function ?
An other question, I tried to use partition
function
on a polygon
with tangente edges (see below), and the
function
return the
whole polygon without partionning it, did I miss
something ?
+-----------------------------____----------+polygon.push_back(Point_2(0,____10));
polygon.push_back(Point_2(0, 0));
polygon.push_back(Point_2(10, 0));
polygon.push_back(Point_2(6, 2));
polygon.push_back(Point_2(2, 2));
polygon.push_back(Point_2(2, 6));
polygon.push_back(Point_2(6, 6));
polygon.push_back(Point_2(10, 10));https://lists-sop.inria.fr/____wws/info/cgal-discuss
Best
Thomas
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
<https://lists-sop.inria.fr/__wws/info/cgal-discuss>
<https://lists-sop.inria.fr/wws/info/cgal-discuss>>
- Re: [cgal-discuss] partitionning Polygon_2 with holes, Thomas Recouvreux, 02/06/2012
- Re: [cgal-discuss] partitionning Polygon_2 with holes, Sebastien Loriot (GeometryFactory), 02/06/2012
- Re: [cgal-discuss] partitionning Polygon_2 with holes, Thomas Recouvreux, 02/07/2012
