- To:
- Subject: Re: [cgal-discuss] Re: SK::circular_arc_point_3 to SK::point_3
- Date: Fri, 10 Feb 2012 11:36:39 +0100
On 02/08/2012 03:41 PM, AdamMiller wrote:
Actually, this functions only works for a meridian which is rational.
Thanks for the advice, but what I really want is an exact meridian vector
for the CompareZatTheta_3 functor. I have a point on the meridian specified
as a circular_arc_point_3 - which is not a vector.
Comparison_result
fo ( SphericalKernel::Circular_arc_3 a0 , SphericalKernel::Circular_arc_3
a1 , SphericalKernel::Vector_3 m )
Do you have any advice?
What you can try it to convert the x and y coordinates of your points
into intervals (using CGAL::to_interval). Then out of this 2 intervals
you can extract two vectors (warning not necessarily inf_x,inf_y and sup_x,sup_y) which defines two meridians: one before, and one after the
one you are interested in. You can call the functor for one these two
meridians (if the result is the same then either they intersect in-between twice, or the order is correct).
If your arcs intersects, you might want to construct the intersection
points and check with Compare_theta_3 that none in between the two
meridians.
By curiosity, what are you using this for?
Sebastien.
thanks again,
Adam Miller
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/SK-circular-arc-point-3-to-SK-point-3-tp4365572p4369639.html
- [cgal-discuss] SK::circular_arc_point_3 to SK::point_3, AdamMiller, 02/07/2012
- Re: [cgal-discuss] SK::circular_arc_point_3 to SK::point_3, Sebastien Loriot (GeometryFactory), 02/08/2012
- [cgal-discuss] Re: SK::circular_arc_point_3 to SK::point_3, AdamMiller, 02/08/2012
- Re: [cgal-discuss] Re: SK::circular_arc_point_3 to SK::point_3, Sebastien Loriot (GeometryFactory), 02/10/2012
- [cgal-discuss] Re: SK::circular_arc_point_3 to SK::point_3, AdamMiller, 02/10/2012
