cgal-discuss - [cgal-discuss] Cannot open CGAL_Core-vc100-mt-gd.lib and error in Boost_INCLUDE_DIR in cmake in configure
  • To:
  • Subject: [cgal-discuss] Cannot open CGAL_Core-vc100-mt-gd.lib and error in Boost_INCLUDE_DIR in cmake in configure
  • Date: Sun, 12 Feb 2012 01:22:59 +0200
Hello my name is Dimitris,
I must do a project from my university and i need to calculate the convex hull of some points, so I must use CGAL.
I use Visual studio 2010. I have downloaded CGAL-3.9  and  boost_1_48_0.
But when I try to use CGAL in my project i got that error
>LINK : fatal error LNK1104: cannot open file 'CGAL_Core-vc100-mt-gd.lib'
The problem is that I can't find that library in my computer to add  a reference to the project's options.
I believe that I didn't do something when I install CGAL. Maybe I have to set some BOOST variables but i don't know how! Cause when i try to compile CGAL with cmake-gui i got the following
Build CGAL from release: CGAL-3.9
Packagenames: CGAL-3.9
CGAL_MAJOR_VERSION=3
CGAL_MINOR_VERSION=9
CGAL_BUGFIX_VERSION=
CGAL_SONAME_VERSION=8
CGAL_SOVERSION =8.0.0
CGAL_REFERENCE_CACHE_DIR=
Building static libraries
Targetting Visual Studio 10 Win64
Target build enviroment supports auto-linking
Using VC10 compiler.
Generator uses intermediate configuration directory: $(Configuration)
USING CMake version: 2.8.7
System: Windows
Build type: Release
USING CXXFLAGS = ' /DWIN32 /D_WINDOWS /W3 /Zm1000 /EHsc /GR -D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE -D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /fp:strict /fp:except- /MD /O2 /Ob2 /D NDEBUG'
USING LDFLAGS = ' '
GMP include: C:/Program Files (x86)/CGAL-3.9/auxiliary/gmp/include
GMP libraries: C:/Program Files (x86)/CGAL-3.9/auxiliary/gmp/lib/libgmp-10.lib
GMP definitions:
USING GMP_VERSION = '5.0.1'
MPFR include: C:/Program Files (x86)/CGAL-3.9/auxiliary/gmp/include
MPFR libraries: C:/Program Files (x86)/CGAL-3.9/auxiliary/gmp/lib/libmpfr-4.lib
MPFR definitions:
USING MPFR_VERSION = '3.0.0'
CMake Error at cmake/modules/FindBoost.cmake:917 (message):
Unable to find the requested Boost libraries.
Unable to find the Boost header files. Please set BOOST_ROOT to the root
directory containing Boost or BOOST_INCLUDEDIR to the directory containing
Boost's headers.
Call Stack (most recent call first):
cmake/modules/CGAL_SetupBoost.cmake:12 (find_package)
cmake/modules/CGAL_SetupDependencies.cmake:32 (include)
CMakeLists.txt:422 (include)
Boost include: Boost_INCLUDE_DIR-NOTFOUND
Boost libraries:
Boost definitions:
USING BOOST_VERSION = '..'
Library config detected: Core
Library config detected: ImageIO
Could NOT find ZLIB (missing: ZLIB_LIBRARY ZLIB_INCLUDE_DIR)
OpenGL include:
OpenGL libraries: glu32;opengl32
NOTICE: CGAL_ImageIO needs ZLib to read compressed files. That feature will not be activated.
Library config detected: Qt3
CGAL_Qt3 needs Qt3, cannot be configured.
Library config detected: Qt4
CGAL_Qt4 needs Qt4, cannot be configured.
Library configs detected: CGAL;Core;ImageIO;Qt3;Qt4
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
Boost_INCLUDE_DIR (ADVANCED)
used as include directory in directory C:/Program Files (x86)/CGAL-3.9/src/CGAL
used as include directory in directory C:/Program Files (x86)/CGAL-3.9/src/CGALCore
used as include directory in directory C:/Program Files (x86)/CGAL-3.9/src/CGALImageIO
used as include directory in directory C:/Program Files (x86)/CGAL-3.9/src/CGALQt3
used as include directory in directory C:/Program Files (x86)/CGAL-3.9/src/CGALQt4
Configuring incomplete, errors occurred!
I would appreciate if someone could help me cause I'm not so experienced and I feel totally lost now and I have very strict deadline.
