Re: [cgal-discuss] Alpha_shape_2::find_optimal_alpha(1) returning invalid pointer value
- To:
- Subject: Re: [cgal-discuss] Alpha_shape_2::find_optimal_alpha(1) returning invalid pointer value
- Date: Mon, 13 Feb 2012 07:15:24 -0000
- Importance: Normal
Hi
I managed to discover the reason why I was having the problem.
I only had two entries in the Alpha array, with the result that
find_optimal_alpha return a value of zero.
Try and dereference that and you get a core dump, I found method that
return the number of entries in the Alpha array and I will not use the
A.find_optimal_alpha until there are at least 3 items in the Alpha array.
Dave.
Sebastien Loriot (GeometryFactory) wrote:
> On 02/11/2012 02:10 PM, Dave Potts wrote:
>> I have inherited a program that uses cgal library, it makes a call to
>> This method returns a value of 0,if you attempt to deference this value,
>> you get a core dump.
>> There is no == operator define for this method so I can not say
>> if(A.find_optimal_alpha(1) ==0)
> try A.find_optimal_alpha(1)!=A.alpha_end()
> but this is quite strange as you should not get alpha_end().
> Do you have a minimal but complete example showing the problem?
> Sebastien.
>> How can I test for a zero return value? or if the values used in A to
>> get an optimal_alpha value are correct?
>> regards
>> Dave Potts.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Alpha_shape_2::find_optimal_alpha(1) returning invalid pointer value, Dave Potts, 02/11/2012
- Re: [cgal-discuss] Alpha_shape_2::find_optimal_alpha(1) returning invalid pointer value, Sebastien Loriot (GeometryFactory), 02/13/2012
- Re: [cgal-discuss] Alpha_shape_2::find_optimal_alpha(1) returning invalid pointer value, Dave Potts, 02/13/2012
