cgal-discuss - [cgal-discuss] Re: Compiling a basic CGAL program in C++ on Mac OS X 10.7.2
  • To:
  • Subject: [cgal-discuss] Re: Compiling a basic CGAL program in C++ on Mac OS X 10.7.2
  • Date: Tue, 14 Feb 2012 06:45:43 -0800 (PST)
Thank you Sebastian but I am still having troubles with CGAL Compilation.
/Sorry I am replying to this a bit late/:
I have made the changes you asked me to do:
/The double /opt/local/ is the cause of your problem.
Check the value of CGAL_MODULES_DIR in the file
$CGAL_DIR/CGALConfig.cmake (which is use to set
CGAL_USE_FILE)
You need to change that file as root.
You can also download the source and compile it yourself.
Now when I compile using CMake GUI(2.8.6) it *Configures* and *Generates*
without giving any error or comments (e.g. /This program requires CGAL so
cannot be compiled/) as before.
Here is the output I got after doing cmake fro Cmake GUI:
The C compiler identification is GNU
The CXX compiler identification is GNU
Checking whether C compiler has -isysroot
Checking whether C compiler has -isysroot - yes
Checking whether C compiler supports OSX deployment target flag
Checking whether C compiler supports OSX deployment target flag - yes
Checking whether CXX compiler has -isysroot
Checking whether CXX compiler has -isysroot - yes
Checking whether CXX compiler supports OSX deployment target flag
Checking whether CXX compiler supports OSX deployment target flag - yes
Build type: Release
USING CXXFLAGS = '-pipe -O2 -arch x86_64 -O3 -DNDEBUG'
USING EXEFLAGS = ' -L/opt/local/lib -arch x86_64
-Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
Targetting Unix Makefiles
Using /usr/bin/c++ compiler.
DARWIN_VERSION=11
Mac Leopard detected
Configuring done
*Now here is my Query:*
After that now when I do *make* to compile the code it gives me a lot of
errors as shown below:
Scanning dependencies of target vd_2_point_location
[100%] Building CXX object
CMakeFiles/vd_2_point_location.dir/vd_2_point_location.cpp.o
In file included from
/Users/singhg/Programming/CGAL-3.9/examples/Voronoi_diagram_2/../../include/CGAL/Bbox_2.h:30,
from
/Users/singhg/Programming/CGAL-3.9/examples/Voronoi_diagram_2/../../include/CGAL/basic_classes.h:30,
from
/Users/singhg/Programming/CGAL-3.9/examples/Voronoi_diagram_2/../../include/CGAL/Cartesian/Cartesian_base.h:28,
from
/Users/singhg/Programming/CGAL-3.9/examples/Voronoi_diagram_2/../../include/CGAL/Simple_cartesian.h:27,
from
/Users/singhg/Programming/CGAL-3.9/examples/Voronoi_diagram_2/../../include/CGAL/Exact_predicates_inexact_constructions_kernel.h:27,
from
/Users/singhg/Programming/CGAL-3.9/examples/Voronoi_diagram_2/vd_2_point_location.cpp:7:
/Users/singhg/Programming/CGAL-3.9/examples/Voronoi_diagram_2/../../include/CGAL/array.h:81:
error: expected nested-name-specifier before ‘...’ token
error: expected ‘>’ before ‘...’ token
/Users/singhg/Programming/CGAL-3.9/examples/Voronoi_diagram_2/../../include/CGAL/array.h:83:
error: template argument 2 is invalid
/Users/singhg/Programming/CGAL-3.9/examples/Voronoi_diagram_2/../../include/CGAL/array.h:84:
error: expected ‘,’ or ‘...’ before ‘&’ token
error: ISO C++ forbids declaration of ‘Args’ with no type
In function ‘int CGAL::make_array(const T&, int)’:
/Users/singhg/Programming/CGAL-3.9/examples/Voronoi_diagram_2/../../include/CGAL/array.h:86:
error: invalid type in declaration before ‘=’ token
error: ‘args’ was not declared in this scope
error: expected `}' before ‘...’ token
error: expected ‘,’ or ‘;’ before ‘...’ token
At global scope:
/Users/singhg/Programming/CGAL-3.9/examples/Voronoi_diagram_2/../../include/CGAL/array.h:87:
error: expected unqualified-id before ‘return’
/Users/singhg/Programming/CGAL-3.9/examples/Voronoi_diagram_2/../../include/CGAL/array.h:88:
error: expected declaration before ‘}’ token
make[2]: *** [CMakeFiles/vd_2_point_location.dir/vd_2_point_location.cpp.o]
Error 1
make[1]: *** [CMakeFiles/vd_2_point_location.dir/all] Error 2
make: *** [all] Error 2
*Please tell me if you know what is going wrong. *
I really appreciate your help.
Thank you
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Compiling-a-basic-CGAL-program-in-C-on-Mac-OS-X-10-7-2-tp4166413p4387215.html
