cgal-discuss - [cgal-discuss] Re: Compiling a basic CGAL program in C++ on Mac OS X 10.7.2
  • To:
  • Subject: [cgal-discuss] Re: Compiling a basic CGAL program in C++ on Mac OS X 10.7.2
  • Date: Wed, 15 Feb 2012 02:29:11 -0800 (PST)
Yes but there are few demos where QGLViewer is not required and my guess is
it might only be required in where 3D structures will be get used. So I
tried to compile L1_Voronoi_diagram_2 and I got these errors:
singhg@~/useful/CGAL-3.9/demo/L1_Voronoi_diagram_2
$ cmake
-DCGAL_DIR=/opt/local/lib/cmake
-- The C compiler identification is GNU
-- The CXX compiler identification is GNU
-- Checking whether C compiler has -isysroot
-- Checking whether C compiler has -isysroot - yes
-- Checking whether C compiler supports OSX deployment target flag
-- Checking whether C compiler supports OSX deployment target flag - yes
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Checking whether CXX compiler has -isysroot
-- Checking whether CXX compiler has -isysroot - yes
-- Checking whether CXX compiler supports OSX deployment target flag
-- Checking whether CXX compiler supports OSX deployment target flag - yes
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- NOTICE: The CGAL_Qt4 library was not configured. Please configure CGAL
using WITH_CGAL_Qt4=ON.
-- Build type: Release
-- USING CXXFLAGS = ' -frounding-math -fno-strict-aliasing -O3 -DNDEBUG'
-- USING EXEFLAGS = '
-Wl,-dylib_file,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib:/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
-- Targetting Unix Makefiles
-- Using /usr/bin/c++ compiler.
-- DARWIN_VERSION=11
-- Mac Leopard detected
-- Looking for Q_WS_X11
-- Looking for Q_WS_X11 - not found.
-- Looking for Q_WS_WIN
-- Looking for Q_WS_WIN - not found.
-- Looking for Q_WS_QWS
-- Looking for Q_WS_QWS - not found.
-- Looking for Q_WS_MAC
-- Looking for Q_WS_MAC - found
-- Looking for QT_MAC_USE_COCOA
-- Looking for QT_MAC_USE_COCOA - found
-- Found Qt4: /usr/local/bin/qmake (found version "4.7.4")
-- *NOTICE: This demo requires CGAL and Qt4, and will not be compiled.*
-- Configuring done
-- Generating done
-- Build files have been written to:
/Users/singhg/useful/CGAL-3.9/demo/L1_Voronoi_diagram_2
I have QT4 and CGAL installed on my system and in these Verbose it was even
said that:
Is there anything else I should look for here?
Thanks!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Compiling-a-basic-CGAL-program-in-C-on-Mac-OS-X-10-7-2-tp4166413p4390001.html
