- To:
- Subject: Re: [cgal-discuss] Re: Delaunay triangulation_2 opengl rendering problem
- Date: Wed, 15 Feb 2012 07:06:04 +0100
On 02/15/2012 05:57 AM, mysmax wrote:
Thank you very much for reply.
I had checked before for line but also the issue is same in your
triangulation demo it is fine when an point is inserted the surrounding
edges renders fine but in my case it is missing does my assign is correct.
regards
mysmax
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Delaunay-triangulation-2-opengl-rendering-problem-tp4387073p4389508.html
This should be rewritten:
pt1=eit->first->vertex(0)->point();
glVertex2d(pt1.x(),pt1.y());
pt2=eit->first->vertex(1)->point();
glVertex2d(pt2.x(),pt2.y());
as:
pt1=eit->first->vertex((eit->second+1)%3)->point();
pt2=eit->first->vertex((eit->second+2)%3)->point();
As you can see here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/TDS_2_ref/Concept_TriangulationDataStructure_2.html#Cross_link_anchor_1336
typedef std::pair<Face_handle,int>
Edge; The edge type. The Edge(f,i) is edge common to faces f and f.neighbor(i). It is also the edge joining the vertices vertex(cw(i)) and vertex(ccw(i)) of f.
Sebastien.
- [cgal-discuss] Delaunay triangulation_2 opengl rendering problem, mysmax, 02/14/2012
- Re: [cgal-discuss] Delaunay triangulation_2 opengl rendering problem, Laurent Rineau (GeometryFactory), 02/14/2012
- [cgal-discuss] Re: Delaunay triangulation_2 opengl rendering problem, mysmax, 02/15/2012
- Re: [cgal-discuss] Re: Delaunay triangulation_2 opengl rendering problem, Sebastien Loriot (GeometryFactory), 02/15/2012
