cgal-discuss - Re: [cgal-discuss] Surface reconstruction without normals
  • To:
  • Subject: Re: [cgal-discuss] Surface reconstruction without normals
  • Date: Thu, 16 Feb 2012 04:30:11 -0800
On Wed, Feb 15, 2012 at 11:10 PM, Sebastien Loriot (GeometryFactory) <> wrote:
1. I don't have normals for my points. My surface is pretty smooth, so
normal estimation should work, but I couldn't find the documentation that
actually described how to do this. Can anyone point me in the right
direction?
Thanks Alex and Sebastien for your help. I stitched the normal-estimation example together with the surface reconstruction one, but got a sphere with a pretty pock-marked surface. It looks as if some of the normals are getting passed through wrong. Here's my code:
http://pastebin.com/WThHKx6p
I'm happy to pass along the output vrml as well, but of course it's sizable. I also tried fiddling with the number of nearest neighbors to use. If I make it smaller, it either can't solve the poisson equation, or gives *really* weird output. If I make it bigger, the surface is smoother, but still has lots of artifacts. Is this just a weakness of the normal estimation algorithm? Shouldn't fitting planes to the neighbors produce a pretty smooth sphere?
- Charlie
