cgal-discuss - Re: [cgal-discuss] Exploration of facets in a convex hull of points
  • To:
  • Subject: Re: [cgal-discuss] Exploration of facets in a convex hull of points
  • Date: Wed, 22 Feb 2012 08:05:29 +0100
For the incremental version in dimension 3, you should use the Delaunay_triangulation_3 to compute it (look at the dynamic example but do not call the conversion function to polyhedron).
Have a look at the file convex_hull_3_to_polyhedron_3.h to see how to get convex_hull facets from a triangulation (taking all cells incident
to the infinite vertex).
For the Convex_hull_d class, facets_begin returns a single-pass iterator
(I know, this is not documented).
Sebastien.
On 02/21/2012 07:20 PM, AP wrote:
Dear all,
I am currently implementing an algorithm that require an incremental
computation of convex hull of points, and I need to know the normal to the
facets of these convex hulls.
The computation is done and updated without any problem following the demo
example "incremental_hull_3_demo.cpp", but I have some strange problems in
the exploration of the facets.
Here is an example below.
int main()
Convex_hull_3 CH(3); // create instance of the class with dimension == 3
/* Insertion of points in the convex hull
facet f,g; /* f and g should be used as iterator to explore the facets
f = CH.facets_begin(); /* f should point on the first facet */
g = f; /* g point also on the first facet */
pl = CH.hyperplane_supporting(f);
std::cout<< pl.a()<< ","<< pl.b()<< ","<< pl.c()<< ","<<
std::endl; /* We print the normal to the first facet */
f++; /* f is incremented and point on the second facet */
std::endl; /* We print the normal to the second facet */
pl = CH.hyperplane_supporting(g); /* g should be unchanged and should
point on the first facet... */
std::endl; /* And we should print the normal of the first facet, however...
exit(0);
However, the printing on the screen is :
900060001,900060001,900060001,
-898079935,-960032,-960032,
I.e. when we increment f, g is also incremented!!!
This makes impossible to use a facet as "current" and the other as "next"
the same way as we would with linked list in the language C. I have tried
some tricks without beeing succesful. I have used a void * to store the
adress pointed by g but it was refused by the compiler, and I have tried to
use a const facet for g but its value was also changed!
Thanks in advance for the help!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Exploration-of-facets-in-a-convex-hull-of-points-tp4407829p4407829.html
