- To:
- Subject: Re: Re: [cgal-discuss] Read IFC building model or VRML file with CGAL
- Date: Wed, 22 Feb 2012 11:39:21 +0100
Le mardi 21 février 2012 23:02:39 Philipp Moeller a écrit :
> Helmi Ben Hmida
> writes:
> > I would like to read the content of an IFC file (or VRML if not) from
> > the CGAL library and store the different geometries inside in the
> > nefPolyhderon Structure in order to apply certain topologic operaion
> > on them later on.
> As Sebastien already told you: The simplest way is probably to convert
> your files to the OFF format [1], use those files to create a
> CGAL::Polyhedron and construct a CGAL::Nef_polyhedron [2] from those files.
> The documentation for Polyhedron [3] even says that it supports VRML
> files, but I have never used this.
Only for writing (with dedicated output streams). There is no input streams
for reading VRML files into a CGAL polyhedron.
Laurent Rineau, PhD
- [cgal-discuss] Read IFC building model or VRML file with CGAL, Helmi Ben Hmida, 02/21/2012
- Re: [cgal-discuss] Read IFC building model or VRML file with CGAL, Philipp Moeller, 02/21/2012
- Re: Re: [cgal-discuss] Read IFC building model or VRML file with CGAL, Laurent Rineau (GeometryFactory), 02/22/2012
