cgal-discuss - Re: [cgal-discuss] Re: cgal configuration problemes
  • To:
  • Subject: Re: [cgal-discuss] Re: cgal configuration problemes
  • Date: Wed, 22 Feb 2012 11:43:39 +0100
Le mardi 21 février 2012 15:18:54 jhodgson a écrit :
> So: Run cmake-gui in Visual Studio shell, but using Run as Administrator
That is really not a good idea. Instead of running the configuration and
compilation process as the administrator, you should better choose as binary
directory, in the CMake GUI, a directory you are allowed to write to!
In the first message of the discussion:
http://cgal-discuss.949826.n4.nabble.com/cgal-configuration-problemes-td4335877.html
"elem" was trying to compile CGAL libraries inside the directory "C:/Program
Files/Microsoft Visual Studio 10.0/"! If you want to destroy your
installation of Windows, I can give you even faster ideas...
Laurent Rineau, PhD
