- To:
- Cc: "Sebastien Loriot (GeometryFactory)" <>
- Subject: Re: [cgal-discuss] CGAL Polydehron VRML Parameters
- Date: Fri, 24 Feb 2012 10:49:40 +0100
Hi,
It means parameters for the Polyhedron color and transparency basicallay to make the visualization more optimal than black objects.
This is a small example:
Appearance {
material Material {
emissiveColor 0.86 0.60 0.75
transparency 0.7
Am 24.02.2012 08:09, schrieb Sebastien Loriot (GeometryFactory):
On 02/23/2012 10:32 PM, Helmi Ben Hmida wrote:
Hi,What does "parametrise the VRML objects" mean?
For visualisation purposes, is there any way to parametrise the VRML
objects files while writing CGAL object in a VRML file via vrml_stream.
Thanks in advance
Sebastien.
BEN HMIDA, Helmi
i3mainz - Institut für Raumbezogene Informations- und Messtechnik
Fachhochschule Mainz - University of Applied Sciences
Lucy-Hillebrand-Str. 2, 55128 Mainz
Raum D0.02
Tel: +49 (0)6131 628 1488
Fax: +49 (0)6131 628 91488
http://www.i3mainz.fh-mainz.de
- [cgal-discuss] CGAL Polydehron VRML Parameters, Helmi Ben Hmida, 02/23/2012
- Re: [cgal-discuss] CGAL Polydehron VRML Parameters, Sebastien Loriot (GeometryFactory), 02/24/2012
- Re: [cgal-discuss] CGAL Polydehron VRML Parameters, Helmi Ben Hmida, 02/24/2012
- <Possible follow-up(s)>
