- To:
- Subject: Re: [cgal-discuss] CGAL Polydehron VRML Parameters
- Date: Fri, 24 Feb 2012 18:50:39 +0100
Sorry, I realized I did not sent the message to you.
-------- Original Message --------
Date: Fri, 24 Feb 2012 11:02:53 +0100
To: Helmi Ben Hmida
There is no generic mechanism to do that.
Have a llok at the file
CGAL/IO/VRML_2_ostream.h
And with some macro processing, you'll be able to define you own methods
to display point, triangles, tets.. (look at operator<< surrounded by
#ifndef CGAL_IO_VRML_2_FOO_3 #endif)
Sebastien.
On 02/24/2012 10:49 AM, Helmi Ben Hmida wrote:
Hi,
It means parameters for the Polyhedron color and transparency basicallay
to make the visualization more optimal than black objects.
This is a small example:
Appearance {
material Material {
emissiveColor 0.86 0.60 0.75
transparency 0.7
Am 24.02.2012 08:09, schrieb Sebastien Loriot (GeometryFactory):
On 02/23/2012 10:32 PM, Helmi Ben Hmida wrote:
Hi,What does "parametrise the VRML objects" mean?
For visualisation purposes, is there any way to parametrise the VRML
objects files while writing CGAL object in a VRML file via vrml_stream.
Thanks in advance
Sebastien.
- [cgal-discuss] CGAL Polydehron VRML Parameters, Helmi Ben Hmida, 02/23/2012
- Re: [cgal-discuss] CGAL Polydehron VRML Parameters, Sebastien Loriot (GeometryFactory), 02/24/2012
- Re: [cgal-discuss] CGAL Polydehron VRML Parameters, Helmi Ben Hmida, 02/24/2012
- <Possible follow-up(s)>
