- To: Philipp Moeller <>
- Cc:
- Subject: 回复: Re: [cgal-discuss] Read IFC building model or VRML file with CGAL
- Date: Sun, 26 Feb 2012 15:11:29 +0800
This is a test email
V
Philipp Moeller
<>编写:
>Helmi Ben Hmida
> writes:
>> I would like to read the content of an IFC file (or VRML if not) from
>> the CGAL library and store the different geometries inside in the
>> nefPolyhderon Structure in order to apply certain topologic operaion
>> on them later on.
>As Sebastien already told you: The simplest way is probably to convert
>your files to the OFF format [1], use those files to create a
>CGAL::Polyhedron and construct a CGAL::Nef_polyhedron [2] from those files.
>The documentation for Polyhedron [3] even says that it supports VRML
>files, but I have never used this.
>HTH,
>Philipp Moeller
>[1] : http://www.holmes3d.net/graphics/offfiles/
>[2] :
>http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Nef_3_ref/Class_Nef_polyhedron_3.html
>[3] :
>http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron/Chapter_main.html#Section_25.4
>You are currently subscribed to cgal-discuss.
>To unsubscribe or access the archives, go to
>https://lists-sop.inria.fr/wws/info/cgal-discuss
- 回复: Re: [cgal-discuss] Read IFC building model or VRML file with CGAL, Rpf, 02/26/2012
