Re: [cgal-discuss] Re: How to offset/inset a general polygon by a certain values?
- To:
- Subject: Re: [cgal-discuss] Re: How to offset/inset a general polygon by a certain values?
- Date: Wed, 29 Feb 2012 08:04:23 +0100
On 02/28/2012 08:39 PM, J_Young wrote:
Sebastien,You are right, I parsed the example too fast. Now I remember your
Yes, the outputs in the example are General_polygon_2, but not the input.
problem is an on-going work at TAU.
In the meantime, something that might work in your case is to
approximate circular arcs by segments (then you'll have a Polygon).
Sebastien.
I tried the following, but I don't know how to add an arc to the polygon.
#include <CGAL/Exact_circular_kernel_2.h>
#include <CGAL/approximated_offset_2.h>
typedef CGAL::Exact_circular_kernel_2 Kernel;
typedef CGAL::Polygon_2<Kernel> Polygon_2;
typedef CGAL::Gps_circle_segment_traits_2<Kernel> Gps_traits_2;
typedef Gps_traits_2::Polygon_2 Offset_polygon_2;
typedef Gps_traits_2::Polygon_with_holes_2 Offset_polygon_with_holes_2;
void approximateInset( )
Polygon_2 P; // how to add an arc into this polygon on the circular kernel?
Kernel::FT radius = 2;
const double err_bound = 0.00001;
std::list<Offset_polygon_2> inset_polygons;
CGAL::approximated_inset_2(P, radius, err_bound,
std::back_inserter(inset_polygons));
*From:* Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden
email] </user/SendEmail.jtp?type=node&node=4429269&i=0>>
*To:* J_Young <[hidden email]
</user/SendEmail.jtp?type=node&node=4429269&i=1>>
*Sent:* Monday, February 27, 2012 11:26 PM
*Subject:* Re: How to offset/inset a general polygon by a certain values?
In the first example here:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Minkowski_sum_2/Chapter_main.html#Subsection_24.3.3
the nested type Gps_traits_2::Polygon_2 is
General_polygon_2<Arr_circle_segment_traits_2<Kernel> >
Sebastien.
On 02/28/2012 12:16 AM, J_Young wrote:
> Sebastien,
> The examples in the following chapter does not work either.
> offset_polygon_2 takes in a Polygon_2 object, not a General_polygon_2
object
> which is what I need.
> Are there other ways?
> Thanks,
> Jay
> View this message in context:
http://cgal-discuss.949826.n4.nabble.com/How-to-offset-inset-a-general-polygon-by-a-certain-values-tp4414852p4426420.html
> Sent from the cgal-discuss mailing list archive at Nabble.com
<http://Nabble.com>.
If you reply to this email, your message will be added to the discussion
below:
http://cgal-discuss.949826.n4.nabble.com/How-to-offset-inset-a-general-polygon-by-a-certain-values-tp4414852p4427297.html
To unsubscribe from How to offset/inset a general polygon by a certain
values?, click here.
NAML
<http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: Re: How to offset/inset a general polygon
<http://cgal-discuss.949826.n4.nabble.com/How-to-offset-inset-a-general-polygon-by-a-certain-values-tp4414852p4429269.html>
<http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
- [cgal-discuss] How to offset/inset a general polygon by a certain values?, J_Young, 02/23/2012
- Re: [cgal-discuss] How to offset/inset a general polygon by a certain values?, Sebastien Loriot (GeometryFactory), 02/23/2012
- [cgal-discuss] Re: How to offset/inset a general polygon by a certain values?, J_Young, 02/23/2012
- Re: [cgal-discuss] Re: How to offset/inset a general polygon by a certain values?, Sebastien Loriot (GeometryFactory), 02/24/2012
- [cgal-discuss] Re: How to offset/inset a general polygon by a certain values?, J_Young, 02/24/2012
- [cgal-discuss] Re: How to offset/inset a general polygon by a certain values?, J_Young, 02/28/2012
- Re: [cgal-discuss] Re: How to offset/inset a general polygon by a certain values?, Sebastien Loriot (GeometryFactory), 02/28/2012
- [cgal-discuss] Re: How to offset/inset a general polygon by a certain values?, cnng0315, 02/29/2012
- Re: [cgal-discuss] Re: How to offset/inset a general polygon by a certain values?, Sebastien Loriot (GeometryFactory), 02/29/2012
