cgal-discuss - Re: [cgal-discuss] Re: Gmp link error , CGAL 3.9, VS2010, boost 1.47, Qt 4.8
  • To:
  • Subject: Re: [cgal-discuss] Re: Gmp link error , CGAL 3.9, VS2010, boost 1.47, Qt 4.8
  • Date: Wed, 29 Feb 2012 10:30:39 +0100
I don't know, the only thing I know is that since VS2005 is not longer
supported, some workaround to correct bugfix in VS2005 are no longer
used and you might have problem later.
If you use cmake to generate the solution to compile the example, it
might be that the gmplib you chose is not the 64bits version
(I am not a windows expert, I just try once to install CGAL on it).
Sebastien.
On 02/29/2012 09:58 AM, JoeTaylor wrote:
Hello Sebastien,
Thank you for your answer.
But seeing in the original post, that VS2010 was used, I thought this could
a be a general issue, with incorrect gmp build or something. Can you
positively state, that the error, in my case can come from the fact that I
am using VS2005? If yes why does it appear in case of VS2010 too?
Thank you in advance!
Kind regards,
Joe
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Gmp-link-error-CGAL-3-9-VS2010-boost-1-47-Qt-4-8-tp4341245p4430973.html
