- To:
- Subject: Re: [cgal-discuss] Re: Gmp link error , CGAL 3.9, VS2010, boost 1.47, Qt 4.8
- Date: Tue, 28 Feb 2012 14:48:02 +0100
Note that VS2005 is no longer supported (see http://www.cgal.org/Manual/latest/doc_html/installation_manual/Chapter_installation_manual.html#Section_2).
Can you try with VS 2008?
Sebastien.
On 02/22/2012 04:02 PM, JoeTaylor wrote:
This post was updated on Feb 21, 2012; 11:22am.
I have the same error, I am trying to build my project using VS2005 on a
Windows 7 64bit version, in 64bit Release mode, both CGAL and Boost are
built in 64bit modes and all my settings are set according as in the
Original post (even the Linker settings, with libgmp-10.lib set corretly)
but still get errors like:
1>main.obj : error LNK2019: unresolved external symbol __imp____gmpz_clear
referenced in function "public: __thiscall
CORE::BigIntRep::~BigIntRep(void)"
(??1BigIntRep@CORE@@QAE@XZ).
Does this has something to do with 64bit Windows versions or the fact that I
am trying to build it in 64bit mode or is the gmp lib wrong?
Kind regards,
Joe
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Gmp-link-error-CGAL-3-9-VS2010-boost-1-47-Qt-4-8-tp4341245p4410601.html
- [cgal-discuss] Re: Gmp link error , CGAL 3.9, VS2010, boost 1.47, Qt 4.8, mysmax, 02/03/2012
- [cgal-discuss] Re: Gmp link error , CGAL 3.9, VS2010, boost 1.47, Qt 4.8, JoeTaylor, 02/22/2012
- Re: [cgal-discuss] Re: Gmp link error , CGAL 3.9, VS2010, boost 1.47, Qt 4.8, Sebastien Loriot (GeometryFactory), 02/28/2012
- [cgal-discuss] Re: Gmp link error , CGAL 3.9, VS2010, boost 1.47, Qt 4.8, JoeTaylor, 02/29/2012
- Re: [cgal-discuss] Re: Gmp link error , CGAL 3.9, VS2010, boost 1.47, Qt 4.8, Sebastien Loriot (GeometryFactory), 02/29/2012
- Re: [cgal-discuss] Re: Gmp link error , CGAL 3.9, VS2010, boost 1.47, Qt 4.8, Andreas Fabri, 02/29/2012
