cgal-discuss - [cgal-discuss] patch: inserting points with info in Periodic_3_Delaunay_triangulation_3
  • To:
  • Subject: [cgal-discuss] patch: inserting points with info in Periodic_3_Delaunay_triangulation_3
  • Date: Thu, 01 Mar 2012 18:10:39 +0100
Hello,
Following up on my question earlier today, I created patches the allow insertion of vertices with info into a Periodic_3_Delaunay_triangulation_3 from eg a vector of such vertices. I'm not sure what is the custom when posting patches, but I created a separate patch for both files involved: Periodic_3_triangulation_3.h and Periodic_3_Delaunay_triangulation_3.h. Also it is not purely a patch that adds the new functionality:
* there was a minor issue in the normal insert(InputIterator, InputIterator) routine in Periodic_3_Delaunay_triangulation_3: points already inserted from the 'points' vector during an initial insertion were re-inserted during the insert_in_conflict() call.
* the special 'is_large_point_set' value, IMHO, should also be present in
the constructor, passing that value on to the call to insert()
* the new functionality of inserting points with info: I followed the same
procedure as in Delaunay_triangulation_3.h and didn't have to invent anything
'new'.
Some other thoughts that came up while working on this:
- Why is this 'insert-with-info' routine only defined in the Delaunay-classes? I wasn't able to find any reason why the exact same function wouldn't work in the respective parent classes Triangulation_3 and Periodic_3_triangulation_3
- When the insert_with_info() routines get presented with the (unfortunate) situation that 'is_large_point_set==true', but the input set is actually small, it will result in a SegmentationFault somehow. I haven't been able to figure out why this happens, but it seems to me that this is not the wanted outcome :P I may have some time later to have a look at this, but since in my application this situation will not occur, unfortunately it will probably end up pretty low on my priority list.
Sincerely,
Jakob van Bethlehem
163a164
> bool is_large_point_set = false,
167c168
< insert(first, last);
> insert(first, last, is_large_point_set);
184a186,194
> #ifndef CGAL_TRIANGULATION_3_DONT_INSERT_RANGE_OF_POINTS_WITH_INFO
> template <class InputIterator>
> std::ptrdiff_t
> insert(InputIterator first, InputIterator last, bool is_large_point_set =
> false,
> typename boost::enable_if<
> boost::is_base_of<Point, typename
> std::iterator_traits<InputIterator>::value_type>
> >::type * = 0
> #else
187c197,199
< bool is_large_point_set = false) {
> #endif
196a209
> Vertex_handle new_vx;
202c215,216
< insert(*pbegin);
> new_vx = insert(*pbegin);
> hint = new_vx->cell();
234c248,358
> private:
> //top stands for tuple-or-pair
> template <class Info>
> const Point& top_get_first(const std::pair<Point,Info>& pair) const {
> return pair.first; }
> const Info& top_get_second(const std::pair<Point,Info>& pair) const {
> return pair.second; }
> const Point& top_get_first(const boost::tuple<Point,Info>& tuple) const {
> return boost::get<0>(tuple); }
> const Info& top_get_second(const boost::tuple<Point,Info>& tuple) const {
> return boost::get<1>(tuple); }
> template <class Tuple_or_pair, class InputIterator>
> std::ptrdiff_t insert_with_info(InputIterator first, InputIterator last,
> bool is_large_point_set)
> if (first == last) return 0;
> size_type n = number_of_vertices();
> // only apply special insertion for empty triangulations:
> if (n > 0) is_large_point_set = false;
> typedef typename Triangulation_data_structure::Vertex::Info Info;
> typedef typename std::vector<std::ptrdiff_t>::iterator Index_handle;
> std::vector<std::ptrdiff_t> indices;
> std::vector<Point> points;
> std::vector<Info> infos;
> for (InputIterator it = first; it != last; ++it)
> Tuple_or_pair value = *it;
> indices.push_back(points.size());
> points.push_back( top_get_first(value) );
> infos.push_back ( top_get_second(value) );
> std::random_shuffle(indices.begin(), indices.end());
> Cell_handle hint;
> std::vector<Vertex_handle> dummy_points;
> Index_handle idx_it = indices.begin(), idx_end = indices.end();
> if (is_large_point_set)
> dummy_points = insert_dummy_points();
> else
> while (!is_1_cover())
> new_vx = insert(points[*idx_it]);
> if (new_vx != Vertex_handle())
> new_vx->info() = infos[*idx_it];
> ++idx_it;
> if (idx_it == idx_end) return number_of_vertices() - n; // all
> points are already in
> // if (is_large_point_set)
> // add remaining points //
> typedef Spatial_sort_traits_adapter_3<Geom_traits, Point *>
> Search_traits;
> spatial_sort(idx_it, idx_end, Search_traits(&(points[0]),
> geom_traits()));
> Conflict_tester tester(points[*idx_it], this);
> Point_hider hider;
> std::vector<Vertex_handle> double_vertices =
> Base::insert_in_conflict_with_info(idx_it, idx_end, points, infos,
> hint, tester, hider);
> typedef CGAL::Periodic_3_triangulation_remove_traits_3< Gt >
> P3removeT;
> typedef CGAL::Delaunay_triangulation_3< P3removeT > DT;
> typedef Vertex_remover< DT > Remover;
> P3removeT remove_traits(domain());
> DT dt(remove_traits);
> Remover remover(this,dt);
> Conflict_tester t(this);
> for (unsigned int i=0; i<dummy_points.size(); i++)
> if (std::find(double_vertices.begin(), double_vertices.end(),
> dummy_points[i]) == double_vertices.end())
> Base::remove(dummy_points[i],remover,t);
> public:
> template<class InputIterator>
> std::ptrdiff_t
> false,
> boost::is_same<typename
> std::iterator_traits<InputIterator>::value_type,
> std::pair<Point, typename
> internal::Info_check<typename Triangulation_data_structure::Vertex>::type>
> >::type* = 0)
> return insert_with_info<std::pair<Point, typename
> template <class InputIterator_1,class InputIterator_2>
> std::ptrdiff_t
> insert( boost::zip_iterator<
> boost::tuple<InputIterator_1,InputIterator_2> > first,
> boost::tuple<InputIterator_1,InputIterator_2> > last, bool
> boost::mpl::and_<
> boost::is_same< typename
> std::iterator_traits<InputIterator_1>::value_type, Point >,
> std::iterator_traits<InputIterator_2>::value_type, typename
> internal::Info_check<typename Triangulation_data_structure::Vertex>::type >
> >::type* = 0
> return insert_with_info< boost::tuple<Point,typename
> #endif //CGAL_TRIANGULATION_3_DONT_INSERT_RANGE_OF_POINTS_WITH_INFO
235a360
868,872c868,874
< template < class InputIterator, class Conflict_tester,
< class Point_hider>
< std::vector<Vertex_handle> insert_in_conflict(
< InputIterator begin, InputIterator end, Cell_handle start,
< Conflict_tester &tester, Point_hider &hider) {
> template < class InputIterator, class Conflict_tester, class Point_hider>
> insert_in_conflict(InputIterator begin, InputIterator end,
> Cell_handle start,
> Point_hider &hider)
887,889c889,891
< CGAL_triangulation_assertion(lta == lt);
< CGAL_triangulation_assertion(ia == li);
< CGAL_triangulation_assertion(ja == lj);
898a901,943
> template <class IndexIterator, class InfoType, class Conflict_tester,
> class Point_hider>
> insert_in_conflict_with_info(IndexIterator begin,
> IndexIterator end,
> std::vector<Point> const &points,
> std::vector<InfoType> const &info,
> Cell_handle start,
> Vertex_handle new_vertex;
> Cell_handle hint;
> std::vector<Vertex_handle> double_vertices;
> Locate_type lt = Locate_type();
> int li=0, lj=0;
> CGAL_triangulation_assertion_code( Locate_type lta = Locate_type(); )
> CGAL_triangulation_assertion_code( int ia = 0; )
> CGAL_triangulation_assertion_code( int ja = 0; )
> while (begin != end)
> tester.set_point(points[*begin]);
> hint = periodic_locate(points[*begin], Offset(), lt, li, lj, start);
> CGAL_triangulation_assertion_code( if (number_of_vertices() != 0) { );
> side_of_cell(points[*begin], Offset(), hint, lta, ia, ja) !=
> ON_UNBOUNDED_SIDE);
> CGAL_triangulation_assertion_code( });
> new_vertex = insert_in_conflict(points[*begin], lt, hint, li, lj,
> tester, hider);
> if (lt == VERTEX) double_vertices.push_back(new_vertex);
> else
> if (new_vertex != Vertex_handle())
> new_vertex->info() = info[*begin];
> start = new_vertex->cell();
> ++begin;
> return double_vertices;
> #endif
