cgal-discuss - Re: [cgal-discuss] patch: inserting points with info in Periodic_3_Delaunay_triangulation_3
  • To:
  • Subject: Re: [cgal-discuss] patch: inserting points with info in Periodic_3_Delaunay_triangulation_3
  • Date: Tue, 06 Mar 2012 17:28:40 +0100
Hello,
Just in case someone besides has already picked up the patch, I noticed a potential problem. I'm just not sure yet what is the cause of the problem; either this patch or some other part of the P3DT3 class. Anywaysz: here's what I noticed:
- when using insert_with_info and the resulting tessellation is still in the 27-sheet coverage space, but the info is only attached to the vertices inside the fundamental domain (namely those you added through the insertion) This may or not be desirable, for me that is no problem.
- however, related (or not), also the offsets for periodic points are always null, even for vertices outside the fundamental domain. I don't have a minimum explicit example, but here's a rough indication:
// assuming I built up some vector 'vec' of not too many pair<Point, Info>
objects,
// and PDT is a correct typedef of a Periodic_3_Delaunay_triangulation_3
class,
// the following would call the insert_with_info() function:
PDT tess(vec.begin(), vec.end());
// next loop over all cells:
auto cell = tess.cells_begin();
auto last = tess.cells_end();
for (; cell != last; ++cell)
int idx;
// now for idx=0,1,2,3 and for each cell
// tess.periodic_point(cell->vertex(idx)).second.is_null() returns true
even though the tessellation is still
Since cells_begin() loops over all cells, including those in the 27-sheeted covering I'd expect that is_null() would only be true for vertices inside the domain, but it actually is true for all cells and all vertices of those cells.
I'm not sure though whether this observation is related to the patch I
created. I have not tested yet what happens using the normal insert(). Maybe
I can find some time to do that later.
Sincerely,
Jakob
On 03/02/2012 05:13 PM, Jakob van Bethlehem wrote:
Hej,
Following up yet again, I found a minor problem in my patch for
Periodic_3_triangulation_3.h. That patch should be replaced with the attached
version.
(btw, these are patches against the 3.9 release version, which I tried to
message across by adding the '-3.9' postfix)
Sincerely,
Jakob van Bethlehem
On 03/01/2012 06:10 PM, Jakob van Bethlehem wrote:
Hello,
Following up on my question earlier today, I created patches the allow
insertion of vertices with info into a Periodic_3_Delaunay_triangulation_3
from eg a vector of such vertices. I'm not sure what
is the custom when posting patches, but I created a separate patch for both
files involved: Periodic_3_triangulation_3.h and
Periodic_3_Delaunay_triangulation_3.h. Also it is not purely a patch that
adds the new functionality:
* there was a minor issue in the normal insert(InputIterator, InputIterator)
routine in Periodic_3_Delaunay_triangulation_3: points already inserted from
the 'points' vector during an initial
insertion were re-inserted during the insert_in_conflict() call.
* the special 'is_large_point_set' value, IMHO, should also be present in the
constructor, passing that value on to the call to insert()
* the new functionality of inserting points with info: I followed the same
procedure as in Delaunay_triangulation_3.h and didn't have to invent anything
'new'.
Some other thoughts that came up while working on this:
- Why is this 'insert-with-info' routine only defined in the
Delaunay-classes? I wasn't able to find any reason why the exact same
function wouldn't work in the respective parent classes
Triangulation_3 and Periodic_3_triangulation_3
- When the insert_with_info() routines get presented with the (unfortunate)
situation that 'is_large_point_set==true', but the input set is actually
small, it will result in a SegmentationFault
somehow. I haven't been able to figure out why this happens, but it seems to
me that this is not the wanted outcome :P I may have some time later to have
a look at this, but since in my application
this situation will not occur, unfortunately it will probably end up pretty
low on my priority list.
Sincerely,
Jakob van Bethlehem
