cgal-discuss - Re: [cgal-discuss] Take the triangles of a polyhedron
  • To:
  • Subject: Re: [cgal-discuss] Take the triangles of a polyhedron
  • Date: Fri, 09 Mar 2012 19:39:22 +0100
sgdimitris
writes:
> Hello,
> I have a list of 3D points and I used the quickhull example from the folder
> "CGAL-3.9\examples\Convex_hull_3"
> to calculate their convex hull. I used the following code to take the list
> of vertices and edges of convex hull
> Polyhedron_3 poly;
> // compute convex hull of non-collinear points
> CGAL::convex_hull_3(points.begin(), points.end(), poly);
> std::cout << "The convex hull contains " << poly.size_of_vertices() << "
> vertices" << std::endl;
> for ( Vertex_iterator v = poly.vertices_begin(); v != poly.vertices_end();
> ++v)
> std::cout << v->point() << std::endl;
> for ( Edge_iterator w = poly.edges_begin(); w != poly.edges_end(); ++w)
> std::cout << "First Vertex of the edge" <<
> w->opposite()->vertex()->point().x() << std::endl;
> std::cout << "Second Vertex of the edge" << w->vertex()->point() <<
> std::endl;
> I need to take the *triangles that connect the vertices of the polyhedron*.
> Is any way to do that?
By "take" you mean iterate over them?
typedef typename Polyhedron_3::Facet_iterator Facet_iterator;
for(Facet_iterator f = polyhedron.facets_begin();
f != polyhedron.facets_end();
++f) {
// your code to work on a face
Philipp Moeller
GeometryFactory
