cgal-discuss - [cgal-discuss] Re: Take the triangles of a polyhedron
  • To:
  • Subject: [cgal-discuss] Re: Take the triangles of a polyhedron
  • Date: Fri, 9 Mar 2012 11:24:40 -0800 (PST)
Thank you for the quick and helpful answer.
Yes I meant iterate by "take".
I would like to ask you one more question. How can I refer to vertices of
each facet.
for example i want to print the vertices of each facet
So I have to do something like
for(Facet_iterator f = polyhedron.facets_begin();
f != polyhedron.facets_end();
++f) {
// Print the vertices
as I did with edges in the following code
for ( Edge_iterator w = poly.edges_begin(); w != poly.edges_end(); ++w)
std::cout << "First Vertex of the edge" <<
w->opposite()->vertex()->point() << " Second Vertex of the edge" <<
w->vertex()->point() << std::endl;
Best regards,
Dimitris
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Take-the-triangles-of-a-polyhedron-tp4460275p4460406.html
