[cgal-discuss] Re: Distance between two Point_3 and distance between a Point_3 and a triangle
- To:
- Subject: [cgal-discuss] Re: Distance between two Point_3 and distance between a Point_3 and a triangle
- Date: Fri, 9 Mar 2012 11:27:41 -0800 (PST)
Thank you Nicholas for your answer,
I will see the links that you posted to me. If there is the solution for
point-plane I can find also point-triangle.
Anyway thank you!!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Distance-between-two-Point-3-and-distance-between-a-Point-3-and-a-triangle-tp4460318p4460426.html
- [cgal-discuss] Distance between two Point_3 and distance between a Point_3 and a triangle, sgdimitris, 03/09/2012
- Re: [cgal-discuss] Distance between two Point_3 and distance between a Point_3 and a triangle, Nicholas Mario Wardhana, 03/09/2012
- [cgal-discuss] Re: Distance between two Point_3 and distance between a Point_3 and a triangle, sgdimitris, 03/09/2012
