[cgal-discuss] Re: Calculate volume of a convex hull (or in general of a polyhedron_3)
- To:
- Subject: [cgal-discuss] Re: Calculate volume of a convex hull (or in general of a polyhedron_3)
- Date: Sat, 10 Mar 2012 02:23:47 -0800 (PST)
Finally, I selected a steady point inside of my convex hull, and create
tetrahedrons with that point and every
triangle (that needed to draw the convex hull). So, I calculated the volume
of its tetrahedron and in the end I added the volumes.
The previous replies helped me to the problem I had.
I post that in case in the future has the same question with me.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Calculate-volume-of-a-convex-hull-or-in-general-of-a-polyhedron-3-tp4455999p4461785.html
- [cgal-discuss] Calculate volume of a convex hull (or in general of a polyhedron_3), sgdimitris, 03/08/2012
- [cgal-discuss] Re: Calculate volume of a convex hull (or in general of a polyhedron_3), ochyomdu, 03/08/2012
- [cgal-discuss] Re: Calculate volume of a convex hull (or in general of a polyhedron_3), sgdimitris, 03/08/2012
- [cgal-discuss] Re: Calculate volume of a convex hull (or in general of a polyhedron_3), hidding, 03/08/2012
- [cgal-discuss] Re: Calculate volume of a convex hull (or in general of a polyhedron_3), sgdimitris, 03/10/2012
