cgal-discuss - Re: [cgal-discuss] Re: How to use CGAL Trang methods
  • To:
  • Subject: Re: [cgal-discuss] Re: How to use CGAL Trang methods
  • Date: Sat, 10 Mar 2012 10:21:52 +0300
Ok but if I want to generate for the source code \Triangulation_3\simple_triangulation_3.cpp then what are the binaries i should indicate for the Cmake. I'm new to cmake and not that familiar with it.
On 10 March 2012 01:56, freckles <> wrote:
Generating the VS solutions with cmake is the same method as when you
generated and compiled the CGAL libs.
Paste the folder path for the example you want into "Where is the source
code" and "Where is the binaries" and click Configure, then Generate. Then
open the .sln file in Visual Studio and build. That's how I usually do it
anyway.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/How-to-use-CGAL-Trang-methods-tp4455754p4460930.html
