- To:
- Subject: Re: [cgal-discuss] install Cgal with windows7, 64 bits, vc10
- Date: Tue, 13 Mar 2012 12:11:41 +0100
Le mardi 13 mars 2012 04:04:30 gwenm a écrit :
> Hi all
> i decided to make a new install of cgal with the secret hope i will succeed
> Given window 7, 64 bits, et visualC2010, do i have to compile CGAL in x64
> configuration or win32 ? (i mean the config proposed in the box on top of
> visual interface ?
We cannot answer you. Do you want to create x86 (32 bits) or x64 (64 bits)
applications?
Note that you need to have a coherent set of dependency libraries (Boost
libraries, Qt4, GMP, GMP, maybe zlib), for the given architecture (x86 or
x84).
I suggest that you start by x86 (win32), because you will find precompiled
versions of the dependencies more easily.
Laurent Rineau, PhD
- [cgal-discuss] install Cgal with windows7, 64 bits, vc10, gwenm, 03/13/2012
- Re: [cgal-discuss] install Cgal with windows7, 64 bits, vc10, Laurent Rineau (GeometryFactory), 03/13/2012
- Re: [cgal-discuss] install Cgal with windows7, 64 bits, vc10, gwenaelle . marquant, 03/13/2012
