cgal-discuss - Re: [cgal-discuss] install Cgal with windows7, 64 bits, vc10
  • To:
  • Subject: Re: [cgal-discuss] install Cgal with windows7, 64 bits, vc10
  • Date: Tue, 13 Mar 2012 12:35:52 +0100 (CET)
ok, thank you. I try with win32 eveywhere .... :)
----- Mail original -----
De: "Laurent Rineau (GeometryFactory)"
À:
Envoyé: Mardi 13 Mars 2012 12:11:41
Objet: Re: [cgal-discuss] install Cgal with windows7, 64 bits, vc10
Le mardi 13 mars 2012 04:04:30 gwenm a écrit :
> Hi all
> i decided to make a new install of cgal with the secret hope i will succeed
> Given window 7, 64 bits, et visualC2010, do i have to compile CGAL in x64
> configuration or win32 ? (i mean the config proposed in the box on top of
> visual interface ?
We cannot answer you. Do you want to create x86 (32 bits) or x64 (64 bits)
applications?
Note that you need to have a coherent set of dependency libraries (Boost
libraries, Qt4, GMP, GMP, maybe zlib), for the given architecture (x86 or
x84).
I suggest that you start by x86 (win32), because you will find precompiled
versions of the dependencies more easily.
Laurent Rineau, PhD
