- To:
- Subject: Re: [cgal-discuss] Minkowski Sum Error
- Date: Thu, 15 Mar 2012 09:04:50 +0200
Make sure that you are using an exact kernel and that the polygons are what we call simple; see definition of "simple" in the manual of the "2D Regularized Boolean Operations" package. If the kernel is and the polygons are, try to reduce the input, and if you believe it's bug report it.
On Thu, Mar 15, 2012 at 2:02 AM, sofia <> wrote:
I'm summing the following polygons with the function /minkowski_sum_2(A, B)/.
Polygon A
(11 vertices)
0 0
6 0
6 -2
7 -2
11 2
11 4
8 4
8 1
2 1
2 4
0 4
Polygon B
(26 vertices)
0 -3
0 0
-17 0
-17 -18
0 -18
0 -9
-6 -9
-6 -10
-1 -10
-1 -17
-8 -17
-8 -14
-9 -14
-9 -17
-16 -17
-16 -10
-9 -10
-12 -7
-16 -7
-16 -1
-10 -1
-10 -6
-8 -6
-8 -1
-2 -1
-2 -3
And I'm getting the following error:
CGAL error: precondition violation!
_expression_ : nodeP != NULL && nodeP->is_valid()
File : (...)\CGAL/Mulitset.h
Line : 338
When I sum A and *B with positive coordinates* the sum works fine.
What can be the problem and how can I fix it?
View this message in context: http://cgal-discuss.949826.n4.nabble.com/Minkowski-Sum-Error-tp4473536p4473536.html
- [cgal-discuss] Minkowski Sum Error, sofia, 03/15/2012
- Re: [cgal-discuss] Minkowski Sum Error, Efi Fogel, 03/15/2012
