- To:
- Subject: Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods
- Date: Thu, 15 Mar 2012 10:20:00 +0300
Check for working C compiler using: Visual Studio 10
Check for working C compiler using: Visual Studio 10 -- broken
CMake Error at C:/Program Files (x86)/CMake 2.8/share/cmake-2.8/Modules/CMakeTestCCompiler.cmake:52 (MESSAGE):
The C compiler "cl" is not able to compile a simple test program.
It fails with the following output:
Change Dir: C:/Program Files (x86)/CGAL-3.9/CMakeFiles/CMakeTmp
Run Build Command:C:\Windows\Microsoft.NET\Framework\v4.0.30319\MSBuild.exe
cmTryCompileExec.vcxproj /p:Configuration=Debug
Microsoft (R) Build Engine Version 4.0.30319.1
[Microsoft .NET Framework, Version 4.0.30319.239]
Copyright (C) Microsoft Corporation 2007. All rights reserved.
Build started 3/15/2012 10:18:07 AM.
Project "C:\Program Files
(x86)\CGAL-3.9\CMakeFiles\CMakeTmp\cmTryCompileExec.vcxproj" on node 1
(default targets).
PrepareForBuild:
Creating directory "cmTryCompileExec.dir\Debug\".
Creating directory "C:\Program Files (x86)\CGAL-3.9\CMakeFiles\CMakeTmp\Debug\".
InitializeBuildStatus:
Creating "cmTryCompileExec.dir\Debug\cmTryCompileExec.unsuccessfulbuild" because "AlwaysCreate" was specified.
ClCompile:
c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\CL.exe /c /Zi /nologo /W3 /WX- /Od /Ob0 /Oy- /D WIN32 /D _WINDOWS /D _DEBUG /D "CMAKE_INTDIR=\"Debug\"" /D _MBCS /Gm- /RTC1 /MDd /GS /fp:precise /Zc:wchar_t /Zc:forScope /Fo"cmTryCompileExec.dir\Debug\\" /Fd"C:/Program Files (x86)/CGAL-3.9/CMakeFiles/CMakeTmp/Debug/cmTryCompileExec.pdb" /Gd /TC /analyze- /errorReport:queue testCCompiler.c /Zm1000
testCCompiler.c
ManifestResourceCompile:
C:\Program Files (x86)\Microsoft SDKs\Windows\v7.0A\bin\rc.exe /nologo /fo"cmTryCompileExec.dir\Debug\cmTryCompileExec.exe.embed.manifest.res" cmTryCompileExec.dir\Debug\cmTryCompileExec_manifest.rc
Link:
c:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\link.exe /ERRORREPORT:QUEUE /OUT:"C:\Program Files (x86)\CGAL-3.9\CMakeFiles\CMakeTmp\Debug\cmTryCompileExec.exe" /VERSION:"0.0" /INCREMENTAL /NOLOGO kernel32.lib user32.lib gdi32.lib winspool.lib shell32.lib ole32.lib oleaut32.lib uuid.lib comdlg32.lib advapi32.lib /MANIFEST /ManifestFile:"cmTryCompileExec.dir\Debug\cmTryCompileExec.exe.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"C:\Program Files (x86)\CGAL-3.9\CMakeFiles\CMakeTmp\Debug\cmTryCompileExec.pdb" /SUBSYSTEM:CONSOLE /STACK:"10000000" /TLBID:1 /DYNAMICBASE /NXCOMPAT /IMPLIB:"C:/Program Files (x86)/CGAL-3.9/CMakeFiles/CMakeTmp/Debug/cmTryCompileExec.lib" /MACHINE:X86 cmTryCompileExec.dir\Debug\cmTryCompileExec.exe.embed.manifest.res
cmTryCompileExec.dir\Debug\testCCompiler.obj /machine:X86 /debug
LINK : fatal error LNK1104: cannot open file 'MSVCRTD.lib' [C:\Program
Files (x86)\CGAL-3.9\CMakeFiles\CMakeTmp\cmTryCompileExec.vcxproj]
Done Building Project "C:\Program Files
(x86)\CGAL-3.9\CMakeFiles\CMakeTmp\cmTryCompileExec.vcxproj" (default
targets) -- FAILED.
Build FAILED.
"C:\Program Files
target) (1) ->
(Link target) ->
LINK : fatal error LNK1104: cannot open file 'MSVCRTD.lib' [C:\Program Files (x86)\CGAL-3.9\CMakeFiles\CMakeTmp\cmTryCompileExec.vcxproj]
0 Warning(s)
1 Error(s)
Time Elapsed 00:00:04.93
CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
CMakeLists.txt:6 (project)
Configuring incomplete, errors occurred!
Installing it directly on C;\ just didn't work :(On 14 March 2012 15:19, Sweety Pie <> wrote:
I will try to uninstall CGAL and install it directly into C:\I didn't find a log file in the mentioned location. :(Will let you know the results after I install it in the new location.On 14 March 2012 12:29, Laurent Rineau (GeometryFactory) <> wrote:
Le mercredi 14 mars 2012 12:17:22 Sweety Pie a écrit :Have also a look to the files C:/Program Files(x86)/CGAL-3.9/CMakeFiles/CMakeTmp/. There may be a log file.
> Thanx for the reply.Other CMake users have that issue. See
> I have read in a tutorial that source and binaries should indicate the same
> location. However, I just created a new folder in another location now for
> the binaries and tried but still the same error happened. It was working
> before on the same directory but I really don't know what happened.
> Any other ideas will be appreciated.
> Thanx for all
http://public.kitware.com/Bug/view.php?id=11967
Can you post the full error message? The one you posted says "there is a
failure" without any more precision?
Maybe you should try to install CGAL-3.9 directory into C:/ instead of
C:/Program Files*/. In the past I saw strange message from CMake because of
the parenthesis in the name of "C:/Program Files (x86)/".
Laurent Rineau, PhD
- Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, (continued)
- Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
- Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/13/2012
- Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Andreas Fabri, 03/13/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/13/2012
- Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/14/2012
- Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/14/2012
- Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/14/2012
- Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/14/2012
- Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/15/2012
- Re: Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Laurent Rineau (GeometryFactory), 03/15/2012
- Re: Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/15/2012
- Re: Re: Re: Re: Re: Re: Re: Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/16/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Andreas Fabri, 03/16/2012
- Re: [cgal-discuss] Re: How to use CGAL Trang methods, Sweety Pie, 03/16/2012
