- To:
- Subject: Re: [cgal-discuss] demo display
- Date: Thu, 15 Mar 2012 18:27:14 +0100 (CET)
I have downloaded and build the demo and example projetcs.
For instance, if i choose triangulation_3_demo , i can build triangulation_3
successfully.
Qt4 is installed.
But next, if i set this project "as startup project" and next F5(execute), i
am told that "this demo requires geomview" .... :-(
----- Mail original -----
De: "Philipp Moeller"
À:
Envoyé: Jeudi 15 Mars 2012 17:59:06
Objet: Re: [cgal-discuss] demo display
gwenm
writes:
> Hi all
> is there a demo or an example that displays a result ? i mean for instance a
> triangulation drawing display ...
> i have looked at some examples but i do not find such a thing (but i did not
> run all examples...).
> thanks in advance
> gwenaelle
There are visual demos for the packages Triangulation_3 that require
Qt4. The demos for the Triangulation_2 package require Qt3, which is
not really around anymore. There are also demos for the Mesh_3 and
Polyhedron package.
Information about how to build can be found in the Installation manual [1].
Philipp Moeller
GeometryFactory
[1] :
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Installation/Chapter_main.html#Section_3.6
- [cgal-discuss] demo display, gwenm, 03/15/2012
- Re: [cgal-discuss] demo display, Philipp Moeller, 03/15/2012
- Re: [cgal-discuss] demo display, gwenaelle . marquant, 03/15/2012
- Re: [cgal-discuss] demo display, Olivier Devillers, 03/16/2012
- Re: Re: [cgal-discuss] demo display, Laurent Rineau (GeometryFactory), 03/16/2012
