- To:
- Subject: Re : [cgal-discuss] How to load a 3D object and use CGAL Trang methods
- Date: Thu, 15 Mar 2012 18:09:27 +0000 (GMT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.fr; h=X-YMail-OSG:Received:X-Mailer:References:Message-ID:Date:From:Reply-To:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=XMzCh/jUABnAwbN1XIgcWagf1QzIJpwKdaf5rg0m32CBZmryOl4FqorocZZ94/sSqbIBjuJA7JwgEvi7muL670QrikHiGyZi0/pOIRcH9FyW7LsX+yC3NkqriEuxIzBFRuTn1thO8W6XVS37d17poRyUb075+jUiuEwiUa0Qvkc=;
Thanks for your reply
what changes should be done on this example so I can triangulate a file ".off" (Where I can get the file name)?
I made a compilation of three triangulation with cgal and I tested the "simple_triangulation_3.cpp" with VisualC + + , I got "Build succeeded" but in the debug , I saw in cmd.exe: press a key to contituer ...
any help plz
De : Philipp Moeller <>
À :
Envoyé le : Jeudi 15 mars 2012 17h43
Objet : Re: [cgal-discuss] How to load a 3D object and use CGAL Trang methods
Zeineb Abderrahim <> writes:
> Hi,
> how can I load a 3d object and what is the most favorite used extension (ply, obj,...) with CGAL? and how I should do to move to the triangulation methode?
> Thanks in advance.
> A. Z
Most CGAL components use the OFF file format [1], although some other
formats are supported as well.
Have a look at the examples in the Triangulation_3 chapter [2] to see
how to use triangulations.
HTH,
Philipp Moeller
GeometryFactory
[1] : http://people.sc.fsu.edu/~jburkardt/data/off/off.html
[2] : http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_3/Chapter_main.html#Section_39.5
- [cgal-discuss] How to load a 3D object and use CGAL Trang methods, Zeineb Abderrahim, 03/15/2012
- Re: [cgal-discuss] How to load a 3D object and use CGAL Trang methods, Philipp Moeller, 03/15/2012
- Re : [cgal-discuss] How to load a 3D object and use CGAL Trang methods, Zeineb Abderrahim, 03/15/2012
