- To:
- Subject: Re: [cgal-discuss] Where is Voronoi_diagram_2.h?
- Date: Fri, 16 Mar 2012 10:02:35 +0100
On 16/03/2012 09:50, Zohar wrote:
I'm using CGAL-4.0-beta1, and I'm missing:
#include<CGAL/Voronoi_diagram_2.h>
#include<CGAL/Delaunay_triangulation_adaptation_traits_2.h>
#include<CGAL/Delaunay_triangulation_adaptation_policies_2.h>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Where-is-Voronoi-diagram-2-h-tp4477635p4477635.html
As we switched from QPL to GPL3+, we needed the ok from the
package owner to do so. As we wanted to stick to the 6 month
release schedule, and as we wanted this license change, we
removed it.
Technically speaking it should be enough to add the CGAL-3.9
include path after the 4.0 include path, so that you find
just the Voronoi package.
We ddin't mix a QPLed and GPLed packages, as the licenses
are incompatible, that is you cannot distribute an application
that contains code under these two licenses.
As it is a purely administrative issue, we hope that it
will be sorted out quickly, so that we can add it again
to the distribution.
andreas
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Where is Voronoi_diagram_2.h?, Zohar, 03/16/2012
- Re: [cgal-discuss] Where is Voronoi_diagram_2.h?, Andreas Fabri, 03/16/2012
- [cgal-discuss] Re: Where is Voronoi_diagram_2.h?, Zohar, 03/16/2012
- Re: [cgal-discuss] Re: Where is Voronoi_diagram_2.h?, Eric Berberich, 03/16/2012
- Re: [cgal-discuss] Re: Where is Voronoi_diagram_2.h?, Laurent Rineau (GeometryFactory), 03/16/2012
- Re: [cgal-discuss] Re: Where is Voronoi_diagram_2.h?, Monique Teillaud, 03/16/2012
