- To:
- Subject: Re: [cgal-discuss] Re: Where is Voronoi_diagram_2.h?
- Date: Fri, 16 Mar 2012 11:15:40 +0100
On 3/16/12 10:03 AM, Zohar wrote:
I finally found something in the history release:
Which is a good file to check before switching to a new release, isn't it?
"2D Voronoi Diagram Adaptor (temporarily removed)"
I mean, I googled for it, searched the index, replacement files, and
nothing. One day just poof it's gone .
Guys, I think you should leave the doc, and replacement headers with
explanation why it's gone, some tips what to use instead, and somewhere the
word deprecate.
As Andreas pointed out, it's not /deprecated/, but we will consider keeping the doc and adding there also "temporarily removed", although we hope that in the next release it is contained again.
eriC
- [cgal-discuss] Where is Voronoi_diagram_2.h?, Zohar, 03/16/2012
- Re: [cgal-discuss] Where is Voronoi_diagram_2.h?, Andreas Fabri, 03/16/2012
- [cgal-discuss] Re: Where is Voronoi_diagram_2.h?, Zohar, 03/16/2012
- Re: [cgal-discuss] Re: Where is Voronoi_diagram_2.h?, Eric Berberich, 03/16/2012
- Re: [cgal-discuss] Re: Where is Voronoi_diagram_2.h?, Laurent Rineau (GeometryFactory), 03/16/2012
- Re: [cgal-discuss] Re: Where is Voronoi_diagram_2.h?, Monique Teillaud, 03/16/2012
