- To:
- Subject: Re: [cgal-discuss] Surface mesh Simplication crashed
- Date: Sun, 18 Mar 2012 14:21:02 +0100
王进
writes:
> Hi,CGAL Developers:
> I use Lindstrom-Turk edge-collapse algorithm for mesh simplification,but
> CGALcrashed at Handle_for.h
> bool
> is_shared() const
> return ptr_->count > 1;
> because of ptr_ is invalid pointer.
> the call stack show as below
> CGAL::Surface_mesh_simplification::EdgeCollapse
> ->boost::put
> ->CGAL::Point_3<CGAL::Cartesian<double> >::operator=
> ->CGAL::PointC3<CGAL::Cartesian<double> >::operator=
> ->CGAL::Vector_3<CGAL::Cartesian<double> >::operator=
> ->CGAL::VectorC3<CGAL::Cartesian<double> >::operator=
> ->CGAL::Handle_for<boost::array<double,3>,std::allocator<boost::array<double,3>
> > >::operator=
> > >::~Handle_for
> > >::is_shared() <---crashed
> for help!
> Wang
A hint first: Don't use Cartesian<double>, performance is probably going
to be a lot better with Simple_cartesian<double>. Simple always means
better, right? ;)
Can you provide a complete, minimal test-case that shows the problem? I
have used Mesh simplification extensively throughout last week and
nothing blew up in my face, but then again I was using Simple_cartesian.
Cheers,
Philipp Moeller
GeometryFactory
- [cgal-discuss] Surface mesh Simplication crashed, 王进, 03/18/2012
- Re: [cgal-discuss] Surface mesh Simplication crashed, Philipp Moeller, 03/18/2012
- Re:Re: [cgal-discuss] Surface mesh Simplication crashed, 王进, 03/18/2012
- Re:Re: [cgal-discuss] Surface mesh Simplication crashed, 王进, 03/20/2012
- Re: [cgal-discuss] Surface mesh Simplication crashed, Philipp Moeller, 03/20/2012
- Re:Re: [cgal-discuss] Surface mesh Simplication crashed, 王进, 03/26/2012
- Re: [cgal-discuss] Surface mesh Simplication crashed, Philipp Moeller, 03/27/2012
