cgal-discuss - Re:Re: [cgal-discuss] Surface mesh Simplication crashed
  • To:
  • Subject: Re:Re: [cgal-discuss] Surface mesh Simplication crashed
  • Date: Tue, 20 Mar 2012 14:18:26 +0800 (CST)
Hi,Philipp Moeller
you are right,Simple_cartesian quite faster than Cartesian,but crashed yet
I provide a piece of test data and code in attachment,please tell me the problem and give me some suggestions.
thanks very much.
WangJin
在 2012-03-18 21:21:02,"Philipp Moeller" <> 写道: >王进 <> writes: > >> Hi,CGAL Developers: >> I use Lindstrom-Turk edge-collapse algorithm for mesh simplification,but CGALcrashed at Handle_for.h   >> >> bool >> is_shared() const >>    { >>         return ptr_->count > 1;    >>     } >> >> because of ptr_ is invalid pointer. >> the call stack show as below >> >> CGAL::Surface_mesh_simplification::EdgeCollapse >> ->boost::put >> ->CGAL::Point_3<CGAL::Cartesian<double> >::operator= >> ->CGAL::PointC3<CGAL::Cartesian<double> >::operator= >> ->CGAL::Vector_3<CGAL::Cartesian<double> >::operator= >> ->CGAL::VectorC3<CGAL::Cartesian<double> >::operator= >> ->CGAL::Handle_for<boost::array<double,3>,std::allocator<boost::array<double,3> > >::operator= >> ->CGAL::Handle_for<boost::array<double,3>,std::allocator<boost::array<double,3> > >::~Handle_for >> ->CGAL::Handle_for<boost::array<double,3>,std::allocator<boost::array<double,3> > >::is_shared() <---crashed >> >> for help! >> >> Wang  > >A hint first: Don't use Cartesian<double>, performance is probably going >to be a lot better with Simple_cartesian<double>. Simple always means >better, right? ;) > >Can you provide a complete, minimal test-case that shows the problem? I >have used Mesh simplification extensively throughout last week and >nothing blew up in my face, but then again I was using Simple_cartesian. > >Cheers, >Philipp Moeller >GeometryFactory > >--  >You are currently subscribed to cgal-discuss. >To unsubscribe or access the archives, go to >https://lists-sop.inria.fr/wws/info/cgal-discuss >
Attachment: test.7z
Description: Binary data
Attachment: TestSurf.7z
