- To:
- Subject: Re: [cgal-discuss] Interval Skip List bug?
- Date: Thu, 29 Mar 2012 08:39:38 +0100
pong!!
Hi Matt,
We will look into it, your analysis might be correct, but we are
currently busy with higher priority tasks.
andreas
On 27/03/2012 18:34, Matt Johnson wrote:
Ping?
On 03/21/2012 03:31 PM, mrj10 wrote:
I was looking at Interval_skip_list.h and noticed what I think might
be a bug
in adjustMarkersOnDelete(). Many places in the code need to do
special-case
check to see if the source or sink of an ISL edge is the ISL header or
footer, but this check is not done in the if statement on line 860 (in
CGAL
4.0). The check is currently:
if(x->forward[i]==0 ||
!m->getInterval()->contains_interval(update[i]->key, x->forward[i]->key))
newDemoted.insert(m->getInterval());
If update[i] is the header, update[i]->key will be garbage (we don't
initialize the header's key in the ISL constructor), so the
contains_interval() call may do something unexpected. It seems like the
check should be:
isHeader(update[i]) ||
The implementation is very clever in other places, so it's entirely
possible
I may have missed an invariant that makes this check unnecessary, but
I've
run into bugs where edges from the header have markers on them, and they
appear to be caused by a bad result from this check.
Best,
Matt
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Interval-Skip-List-bug-tp4493660p4493660.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Interval Skip List bug?, mrj10, 03/21/2012
- Re: [cgal-discuss] Interval Skip List bug?, Matt Johnson, 03/27/2012
- Re: [cgal-discuss] Interval Skip List bug?, Andreas Fabri, 03/29/2012
