- To:
- Subject: [cgal-discuss] 3D mesh with surface preserved
- Date: Tue, 03 Apr 2012 01:03:01 +0200
Hello,
is it possible to set the mesh criteria in such a way that the surface mesh which I pass to CGAL will be preserved and CGAL will only insert points/elements inside the volume bound by my surface? Could you please share an example code?
Thank you.
Martin Vymazal
This message was sent using IMP, the Internet Messaging Program.
- [cgal-discuss] Triangulation_2 with info, edward, 04/02/2012
- Re: [cgal-discuss] Triangulation_2 with info, Sebastien Loriot (GeometryFactory), 04/02/2012
- [cgal-discuss] Re: Triangulation_2 with info, edward, 04/02/2012
- [cgal-discuss] 3D mesh with surface preserved, Martin Vymazal, 04/03/2012
- Re: [cgal-discuss] 3D mesh with surface preserved, Sebastien Loriot (GeometryFactory), 04/03/2012
