- To:
- Subject: Re: [cgal-discuss] 3D mesh with surface preserved
- Date: Tue, 03 Apr 2012 08:30:03 +0200
On 04/03/2012 01:03 AM, Martin Vymazal wrote:
Hello,With the current implementation this is not possible, the surface will
is it possible to set the mesh criteria in such a way that the surface
mesh which I pass to CGAL will be preserved and CGAL will only insert
points/elements inside the volume bound by my surface? Could you please
share an example code?
always be re-meshed.
Sebastien.
Thank you.
Martin Vymazal
This message was sent using IMP, the Internet Messaging Program.
- [cgal-discuss] Triangulation_2 with info, edward, 04/02/2012
- Re: [cgal-discuss] Triangulation_2 with info, Sebastien Loriot (GeometryFactory), 04/02/2012
- [cgal-discuss] Re: Triangulation_2 with info, edward, 04/02/2012
- [cgal-discuss] 3D mesh with surface preserved, Martin Vymazal, 04/03/2012
- Re: [cgal-discuss] 3D mesh with surface preserved, Sebastien Loriot (GeometryFactory), 04/03/2012
