cgal-discuss - [cgal-discuss] Question about linear_least_squares_fitting_3
  • To:
  • Subject: [cgal-discuss] Question about linear_least_squares_fitting_3
  • Date: Tue, 3 Apr 2012 09:52:09 -0700 (PDT)
Hi everyone,
The function linear_least_squares_fitting_3 to estimate best fitting plane
seems to obtain unexpected results when the points are generated from a
specific plane.
I randomly constructed a plane and then retrived some points from this
plane. Another new plane is estiamted by these points utilizing funtion
linear_least_squares_fitting_3. But these two planes are not the same!
Here are main codes:
boost::mt19937 eng; // a core engine class:Mersenne
eng.seed(time(NULL));
boost::uniform_real<> unif01(-1,1); //<>不可少
boost::uniform_real<> unif100(-100,100);
boost::variate_generator<boost::mt19937&amp;,
boost::uniform_real&lt;> >
random01(eng, unif01);
random100(eng, unif100);
Plane_3 plane(random01(),random01(),random01(),random100());
cout<<"Origin plane "<<plane&lt;&lt;endl;
list&lt;Point_3> pts;
int N=10;
for(int i=0;i<N;++i)
double x, y,z;
x=random100();
y=random100();
xy2z(plane,x,y,z);//User defined function, from x or y to
retrive z from
plane
pts.push_back(Point_3(x,y,z));
for(list&lt;Point_3>::iterator
iter=pts.begin();iter!=pts.end();++iter)
cout<<"Point to Plane Dist "<<CGAL::squared_distance(*iter,
plane)&lt;&lt;endl;
Plane_3 plane1;
cout&lt;&lt;endl;
cout&lt;&lt;&quot;CGAL Fitting result &quot;&lt;&lt;
CGAL::linear_least_squares_fitting_3(pts.begin(),pts.end(),plane1,
CGAL::Dimension_tag&lt;0>());
cout<<endl;
cout&lt;&lt;&quot;cgal plane &quot;&lt;&lt;plane1&lt;&lt;endl;
//cout<<*iter<<endl;
cout&lt;&lt;&quot;Point to Plane Dist
&quot;&lt;&lt;CGAL::squared_distance(*iter, plane1)&lt;&lt;endl;
The output is:
Origin plane &lt;b>-0.456603 0.437936 -0.276328 -49.6504*
Point to Plane Dist 0
Point to Plane Dist 4.23699e-028
Point to Plane Dist 1.65507e-030
Point to Plane Dist 1.6948e-027
CGAL Fitting result 1
cgal plane *-0.661375 0.634336 -0.400252 -71.917*
Point to Plane Dist 1.01102e-017
Point to Plane Dist 2.73393e-018
Point to Plane Dist 9.74678e-018
Point to Plane Dist 1.0964e-015
Point to Plane Dist 6.0825e-016
Point to Plane Dist 1.66278e-016
Point to Plane Dist 1.23536e-015
Point to Plane Dist 2.27407e-016
Point to Plane Dist 2.63125e-018
Point to Plane Dist 3.43804e-016
Press any key to continue . . .
It seems that the fitting results, point to plane squared distance is good,
but plane equation are quite different. How does this happens?
Hope you could help
Best regards
Edward
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Question-about-linear-least-squares-fitting-3-tp4529464p4529464.html
