- To:
- Subject: [cgal-discuss] Re[2]: Determining if a point is inside a polyhedron
- Date: Thu, 12 Apr 2012 06:55:19 -0700 (PDT)
Hi Daisy! That's definitely a possible way to eliminate the points
that fall inside the other figure. Using locate() seems to be an
easier way, but I guess I'm doing something wrong and haven't managed
to get it working yet.
Oleg
Wednesday, April 11, 2012, 20:14, you wrote:
> Hi,
> In my oppinion, you can have a try with the deviation.
> Let *n* be a unit normal vector from the origin to the plane PI, and M
> be a point in 3D space. Make a line segment MQ from the M to the plane PI,
> and let MQ be perpendicular to PI at point Q. Then the projection from the
> vector QM to the normal vector n is called deviation between M and PI.
> http://cgal-discuss.949826.n4.nabble.com/file/n4548847/4.bmp
> Obviously, we can judge the M's position, on one side of the PI, or the
> other. Especially, if we use the normalized plane equation, we can compute
> the deviation easier.
> I am not sure if I can help you. Good luck.
> _______________________________________________
> If you reply to this email, your message will be added to the discussion below:
> http://cgal-discuss.949826.n4.nabble.com/Determining-if-a-point-is-inside-a-polyhedron-tp4523460p4548847.html
> To unsubscribe from Determining if a point is inside a polyhedron,
> visit
View this message in context: Re[2]: Determining if a point is inside a polyhedron
- [cgal-discuss] Determining if a point is inside a polyhedron, Oleg, 04/01/2012
- Re: [cgal-discuss] Determining if a point is inside a polyhedron, Sebastien Loriot (GeometryFactory), 04/02/2012
- [cgal-discuss] Re[2]: Determining if a point is inside a polyhedron, Oleg, 04/03/2012
- [cgal-discuss] Re: Re[2]: Determining if a point is inside a polyhedron, Zohar, 04/03/2012
- Re: [cgal-discuss] Re[2]: Determining if a point is inside a polyhedron, Sebastien Loriot (GeometryFactory), 04/04/2012
- [cgal-discuss] Re[4]: Determining if a point is inside a polyhedron, Oleg, 04/10/2012
- Re: [cgal-discuss] Re[4]: Determining if a point is inside a polyhedron, Sebastien Loriot (GeometryFactory), 04/11/2012
- [cgal-discuss] Re[6]: Determining if a point is inside a polyhedron, Oleg, 04/11/2012
- [cgal-discuss] Re: Determining if a point is inside a polyhedron, daisy, 04/11/2012
- [cgal-discuss] Re[2]: Determining if a point is inside a polyhedron, Oleg, 04/12/2012
