- To:
- Subject: [cgal-discuss] Image_3 from a std::vector
- Date: Thu, 12 Apr 2012 12:19:28 -0700 (PDT)
I have a std::vector of integer image data, organized in column format. I
need to set the data associated with an Image_3 objected to the data in this
vector. Can I do this with the Image_3::set_data member function? If so, how
is this done?
Thanks,
Andrew
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Image-3-from-a-std-vector-tp4552785p4552785.html
- [cgal-discuss] Image_3 from a std::vector, slaughter, 04/12/2012
- Re: [cgal-discuss] Image_3 from a std::vector, Laurent Rineau (GeometryFactory), 04/12/2012
- [cgal-discuss] Re: Image_3 from a std::vector, slaughter, 04/12/2012
- Re: [cgal-discuss] Re: Image_3 from a std::vector, Laurent Rineau (GeometryFactory), 04/12/2012
