cgal-discuss - Re: [cgal-discuss] Re: Image_3 from a std::vector
  • To:
  • Subject: Re: [cgal-discuss] Re: Image_3 from a std::vector
  • Date: Thu, 12 Apr 2012 22:35:04 +0200
Le jeudi 12 avril 2012 13:19:20 slaughter a écrit :
> What do you mean by this: "If 'image' is a default initialized Image_3
> object".
> I am creating my Image_3 as:
> CGAL::Image_3 im;
> The set_data command as you suggested is causing a Segmentation fault.
You are right. I forgot that the _image struct must be initialized.
Use that:
CGAL::Image_3 image(_createImage(xdim, ydim, zdim, 1,
vx, vy, vz,
1, WK_FIXED, SGN_UNSIGNED));
ImageIO_free(image.data());
image.set_data(&data[0]);
The last three parameters, 1, WK_FIXED, and SGN_UNSIGNED depends on the
value_type of your vector.
Laurent Rineau, PhD
