[cgal-discuss] Convert M_float to double & the missing code in the width_simplex.cpp
- To:
- Subject: [cgal-discuss] Convert M_float to double & the missing code in the width_simplex.cpp
- Date: Sat, 14 Apr 2012 04:11:37 -0700 (PDT)
First, about M_Float. I want to use the width_simplex example of CGAL.
However, the output resut is expressed by the type MP_Float defined by
cgal. I want to convert the type to double or float. Or I can't compare the
it with my own method. How can I convert the type for output?
Second, about width_simplex.cpp. I think some codes is missing in this file.
/Plane_3 e1, e2;
std::cout << "Planes: E1: " << e1 << ". E2: " << e2 <<std::endl;</i>
Obviously, there are no values about el and el. The missing codes should be:
*simplex.get_width_planes(e1,e2); *
Finally, what is the algorithm adopted by the width_simplex? Is there any
reference paper published?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Convert-M-float-to-double-the-missing-code-in-the-width-simplex-cpp-tp4557009p4557009.html
- [cgal-discuss] Convert M_float to double & the missing code in the width_simplex.cpp, daisy, 04/14/2012
