- To:
- Subject: Re: [cgal-discuss] Re: How to use the examples of CGAL
- Date: Sat, 14 Apr 2012 13:02:04 +0200
daisy
writes:
> After I add or modify some codes to the file *width_simplex.cpp*, the
> example's output change with to my modification if I configure and generate
> the examples again by Cmake. Because the file *width_simplex.exe *would not
> update. I must build solution by vs2010, the *width_simplex.exe * will be
> updated.Then, I launch the .exe file, the result changes with my
> modification.
Yes, if you change a source you have to rebuild the target
executable. Maybe I don't understand you correctly, but where is the
problem?
Cheers,
Philipp Moeller
GeometryFactory
- [cgal-discuss] How to use the examples of CGAL, (continued)
- [cgal-discuss] How to use the examples of CGAL, daisy, 04/13/2012
- [cgal-discuss] Re: How to use the examples of CGAL, daisy, 04/13/2012
- Re: [cgal-discuss] Re: How to use the examples of CGAL, Laurent Rineau (GeometryFactory), 04/13/2012
- [cgal-discuss] Re: How to use the examples of CGAL, daisy, 04/14/2012
- Re: [cgal-discuss] Re: How to use the examples of CGAL, Philipp Moeller, 04/14/2012
